2006 6.0L Lots of smoke out Tail
Hi everyone. New here. I have a 2006 F-250 Lariat 6.0L and as far as i know there are no mods(bought with 109k) other than I removed EGR. I change oil every 5k and fuel filters 10k. I was towing my camper home and truck started blowing black smoke. It doesn't seem to have a loss of power but does idle rough. I figured i had a sticky injector so I added a bottle of injector cleaner to just over a half tank of fuel(~13G). I drove the last 50 miles, which used over a quarter tank, and smoke persisted. I borrowed a Snap On scanner and checked for codes but only the EGR codes were present. I ran injector buzz test and that checked good. Turned off each injector individually and each one made engine run rougher. FICM voltage is 47-47.5. ICP is 580-600psi at idle and increases with throttle. Ran contribution test and cylinders seem to randomly drop below zero with no misfires reported.
Long story short I am at a loss. My thinking is still a stuck injector but dont want to throw hard earned cash at dumpster fire.
Thanks in advance for any suggestions.
Wanted to update this post. After talking to more people and running every test I could i decided that there was and injector letting too much fuel in. I bit the bullet and ordered a full set of injectors. I found the pictured injector in cylinder #1. As you can see the lower O-Ring is blown out allowing fuel to dump into cylinder.
bigpowerstroke
18
01-12-2012 02:48 PM
Dbailey
13
05-31-2010 11:55 AM
