Quick 2018 5.0 towing report
Old Jul 23, 2018 | 02:02 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Did a quick camping trip last week, here’s there results.
Towing a camper just under 5000 pounds. Probably another 750-1000 pounds of gear in the truck. Trip was about 190 miles consisting of ~150 of highway, 40 miles of 30-45 mph secondary roads. Speed on the highways was mostly ~65, the cruise control set to that speed. Drive mode was “Tow/Haul” 100% of the time.
Total mileage is a little less on the return info as I initially forgot to reset the trip info. Weight on the return was probably 300-400 pounds less as I drained the water tank in the camper before returning, and we drank all the beer I brought out. Note that this was not an attempt to get the best mpg possible, but to record the mpg the way I’d normally drive. I was very impressed with the power of the 5.0, great acceleration even at highway speeds. It was interesting to watch the gears the 10 speed chose, it did what I considered a very good job.
Edit: Removed two gears from the tranny.
Out:
Return:
Old Jul 23, 2018 | 03:41 PM
smokewagun's Avatar
smokewagun
Don't tell me YOU are the guy who got the only twelve speed made? Just kidding. 😜
Great to hear. Im teething to get a travel trailer again and see how my 5.0L performs. Thanks for sharing.
Old Jul 23, 2018 | 03:57 PM
JKBrad's Avatar
JKBrad
12, if you count neutral and reverse.
Old Jul 23, 2018 | 05:57 PM
92F350CC's Avatar
92F350CC
Funny enough I know a guy who swears up and down that his 2002 7.3 came from the factory with an Allison due to a joint venture between Ford and GM.
Naturally I started mocking Allison a few years later when his 4R100 failed.
Old Jul 23, 2018 | 06:36 PM
brokenleg's Avatar
brokenleg
What is your gear ratio? And is it 4x4?
Old Jul 23, 2018 | 07:09 PM
NewEnglandHerdsman
What? How many did you get? Only 10? Crap, I'd complain!
Maybe it was spell checking, lol?
Old Jul 23, 2018 | 07:11 PM
NewEnglandHerdsman
Sorry, I swore I put that info in the post. But I also said it was a 12 speed, so...
3.31, 4WD
One added comment: I found the truck's mpg calculation was pretty accurate. There were some miles driven - maybe 20 miles or so - before and after the 191 trip mileage, before I topped it off with 15.004 gallons. So 211 miles / 15.004 gallons yields 14.06 mpg
Old Jul 23, 2018 | 07:54 PM
brokenleg's Avatar
brokenleg
3.31, 4WD
Cool. My truck has 3.73s.... and the 6.2. (2013 F150).. I ask because maybe in the next few years I plan to buy a 5.0 truck..but not sure what gears to get. I know gears have a big affect on fuel economy
Old Jul 23, 2018 | 09:42 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's about what I see in my 16 F150 5.0 3.31 4X4 towing up the Colorado passes. If I am really hammering on it I'll get down to 12.5, but 14-14.5 is a good average. Steady highway is about 16mpg.
Old Jul 24, 2018 | 06:38 AM
NewEnglandHerdsman
My guess is that with the 10 speed, the diff gearing matters much less, as with the 10 speed there are just many more gear options over even the 6 speeds. When in tow/haul mode even well below the max towing weight I rarely if ever got in to 10th gear. So with the same load, when a 3.31 is in say 7th, a 3.73 might be in 8th, i.e. final gearing is all that is important. (The above just an estimate, I didn't do the actual numbers.)
Old Jul 26, 2018 | 10:46 AM
Sirikenewtron's Avatar
Sirikenewtron
How much weight are you towing when you do that trip?
Old Jul 26, 2018 | 08:43 PM
Bullitt390's Avatar
Bullitt390
Around 5000 pounds, plus camping gear etc in the truck.
Old Jul 26, 2018 | 08:49 PM
Sirikenewtron
Very nice, and the 5.0 does good at those elevations and grades?
Old Jul 26, 2018 | 10:03 PM
Bullitt390's Avatar
Bullitt390
For sure. No complaints at all at altitude or pulling loads. I occasionally pull a 10k Kubota tractor. Doesn’t break a a sweat.
moisesmelo
2015 - 2020 F150
Aug 12, 2018 05:52 PM
PrinceValium
2009 - 2014 F150
20
Aug 9, 2015 06:33 PM
bama29fan
6.7L Power Stroke Diesel
15
Jun 15, 2012 08:09 AM
DrewF
Nov 15, 2011 06:59 AM
elcapitan
Jun 6, 2011 12:04 PM
