Short Oil Change Interval
Old Jul 23, 2018 | 11:13 AM
Texaswilliam's Avatar
Texaswilliam
I have a new 2017 F250 6.7 diesel. At about 6,500 miles, without any indication from the truck that I needed an oil change, I changed the oil and filter. I used Rotella T6 full synthetic.
Today, with 9,500 miles on the truck, the “change engine oil soon” message came on on the dash. I would guess I have towed my Airstream about 1,200 of those miles.
I thought the Ford system is suppose to analyze the oil? I’m suspicious that the message came up at 9,500....seems like a 10,000 mile indicator.
could I really need an oil change this quickly?
Old Jul 23, 2018 | 11:22 AM
harmanrk's Avatar
harmanrk
When you changed the oil, did you reset the oil life monitor, so the truck knows you changed it?
There have been reports of the OLM calling for a change after that few miles, but most are the user not resetting the meter.
Old Jul 23, 2018 | 12:00 PM
nuctrooper's Avatar
nuctrooper
Do you have FORSCAN? Pull the "miles since last oil change" PID. That'll confirm if it is just a matter of forgetting to reset, or if you need to look across other oil parameters for dilution, etc.
Old Jul 23, 2018 | 12:11 PM
Blwnsmoke's Avatar
Blwnsmoke
You need to rest it as stated so the truck knows you changed it. Then it will restart its tracking for the next oil change. It is all in your manual.. you know that book you get with the truck lol.
It does not analyze the actual oil but it does monitor many different things (idle time, rpm, hours, miles etc and more.)
Old Jul 23, 2018 | 04:56 PM
zeroo's Avatar
zeroo
If he didn’t reset it I would think the messages would be constantly popping up. They first start with change engine oil soon, then they say change engine oil now.
also, OP, the oil isn’t analyzed Chemically, just the circumstances that the truck goes through. Do you idle a lot also? You may be towing and using the truck in what is considered severe conditions.
Old Jul 23, 2018 | 07:39 PM
18CCLBKR's Avatar
18CCLBKR
Will the truck say to change the oil if you overheat the oil like on a bmw? Just a thought.
MPNX2
Aug 26, 2018 12:43 PM
cub22908
May 11, 2018 05:18 PM
SHOpar
6.7L Power Stroke Diesel
28
Nov 14, 2015 12:07 PM
KPT
Jun 13, 2013 07:27 AM
blueheron
May 24, 2011 08:33 PM
