Manual brakes with front Discs ???
New here, I have a question about a truck I bought..
It`s a `79 F100 with front disc brakes but there`s no vacuum booster,just manual brakes,
My question is :
if this is how it was made or if it`s a conversion?
Ive had manual brakes in a `74 F100 but it had drums, All I can tell you about the truck is it has a straight six, 4 speed manual trans and manual steering, pretty much as (plain jane) as you can get but it has no rust and runs good for the $800.00 I paid, It stops ok but I`m leaning toward the notion its been tinkered with at some point,I hope I can get some advice on the brakes, thanx in advance for any info..
My question is :
Same here,
--But I performed the brake upgrade noted in the Tech articles by using T-Bird calipers and an F-350 booster/MC. Works fabulously as long as you have good compression/vacuum from the engine.
The hardest part of the install was finding the correct brackets to mount the booster to the truck (junkyard) and having to replumb the brake lines going to the MC with suitable fittings.
schwefel69
13
11-21-2013 11:51 AM
boathaulin76
06-22-2009 01:05 PM
Nathan Plemons
06-21-2009 08:04 AM
clint1274
10-24-2002 04:35 PM
