How does the hub come off?!!
Old Sep 22, 2003 | 03:23 PM
GeoQwest's Avatar
GeoQwest
Angry How does the hub come off?!!
Okay...what am I missing here.
I need to get into my 2000 Excursion hubs for cleaning and lube.
One side is sticking and sometimes goes in/out on auto and sometimes doesn't like to.
I've taken the external snap ring off but the black sleeve will not come off. Plying with 2 screwdrivers on each side doesn't do it.
Is there a trick?
I've posted a picture of the model of hub at https://www.ford-trucks.com/user_gal...=24332&width=0
Thanx...GeoQwest
Old Sep 22, 2003 | 03:49 PM
Big Orn's Avatar
Big Orn
They can be a pain sometimes, but better than prying, try to tap it off (lightly) with a rubber malet or a block of soft wood. Tap it all around with an outward persuasion until it frees up inside. There is nothing else holding it in - except for road scum, dirt, grit, mud, etc.
I lifted my axle so that I could spin the wheel and tapped on it until finally it broke loose.
Old Sep 22, 2003 | 04:52 PM
GeoQwest's Avatar
GeoQwest
Thumbs up How does the hub come off?!!
I gave up for today but I'll give it a go tomorrow.
I did everything you mentioned with the axle off the ground. It was good to compare both hubs and to be able to rotate the wheel to see how sticky the hubs were.
I managed to spray a good dose of WD-40 past the plastic selector and the snap ring area so it might ease things up for tomorrow.
Thanx again...cheers...GeoQwest
GeoQwest
Jul 8, 2010 05:52 PM
GeoQwest
Jul 10, 2005 12:10 AM
GeoQwest
Aug 26, 2004 12:31 PM
GeoQwest
Sep 23, 2003 09:53 PM
GeoQwest
Modular V10 (6.8l)
Sep 23, 2003 08:45 PM
