Aerostar Ford Aerostar
Overdrive issue..
Old Jul 22, 2018 | 04:41 AM
Goethfather's Avatar
Goethfather
Overdrive issue..
Hello.
So i have my Ford Aerostar 95 XTL E4WD V6 4.0L.
My overdrive have stopped working ... it started a while ago, it sometimes wanted to in to overdrive at 70 km/h and sometimes not...
Then i changed my transmission filter and oil, and it still only wanted to go in to overdrive from time to time..
Now it TOTALLY stopped working, what can it be ?
Old Jul 28, 2018 | 07:06 AM
sittinguy's Avatar
sittinguy
Could as simple as the modulator??
Pretty Van!
Old Jul 28, 2018 | 08:50 AM
Goethfather
Pretty Van!
The modulator??
Thx!
Old Jul 28, 2018 | 01:40 PM
sittinguy's Avatar
sittinguy
https://www.carid.com/fram/automatic...pn-fm2336.html
Look for a vacuum leak also
Old Jul 28, 2018 | 08:02 PM
xlt4wd90's Avatar
xlt4wd90
Does the 95 model still use a vacuum modulator? If it does, pull off the vacuum line to see if there is ATF in it. If so, the diaphragm has broken, and it does need to be replaced. I've never done this before, but I read that there is a pin that can fall out when you pull out the modulator, so be careful when doing that. There is a heat shield covering that area to protect it from the catalytic converter, so that has to be removed first. But some people have trouble pulling/installing because the cat con is in the way.
Cracker289
Aug 24, 2012 12:44 PM
90_Shorty
Aerostar
Sep 20, 2006 08:43 AM
chews32
Oct 10, 2004 06:04 PM
kerry2u2
Apr 18, 2003 11:07 PM
