I have a 2004 F250 leaf spring front truck and I’m looking to buy some new 20” wheels. I currently have 16” wheels with 285 75 16 tires on them. The truck is leveled in the front and has an add a leaf in the rear. I did a lot of research and I decided against using spacers (I was planning to run newer oem stock 20” wheels. I’m on the hunt for a 20” aftermarket wheel setup but I’m not certain exactly what to get.
20”x10” with -18mm will the tire come out of the wheel well? I don’t want some crazy tires coming out but I want it to look right.
Will 35” tires clear everything ok with the weight of a plow on the truck turning all the way from one side to the other?
Please post some pictures of your wheel / tire sizes and lmk what you think. Thank you.
