Tire Help !!!!
Old Jul 20, 2018 | 05:51 PM
dragond80's Avatar
dragond80
Tire Help !!!!
Has anyone run Military spec 37x12.5 R 16.5 tires on the F250-F350 I am currently running 31x10.5 R 16.5 My question is this, is it worth it switch and do you need to mod the truck when you do ? ( wheel spacer, lift kit )
Old Jul 21, 2018 | 08:23 PM
flatbedfordguy's Avatar
flatbedfordguy
I am assuming you're referring to 4x4, if so, the stock F250 can clear 37's if the springs are fresh (original ride height), but if they're worn (sagging) you're going to rub.
Old Jul 22, 2018 | 12:30 AM
dragond80's Avatar
dragond80
No, actually I own the f350 one ton 2 wheel drive, but I love it and that's why I was asking.
Old Jul 22, 2018 | 06:53 AM
Number4's Avatar
Number4
305’s are about the biggest that will fit my 2wd. They are equivalent to your 31’s I believe. They rubbed at full turn on my ‘79 F250 so the 37’s would be worse. I’d say no.
Edit:
315/70’s were quite a bit bigger and would not fit my 2wd, the tires you are looking at are equivalent to 318/82’s.
Old Jul 22, 2018 | 12:26 PM
dragond80's Avatar
dragond80
So in order for me to use those mil spec tires, I'll have to get a lift on the truck before using them. oh bummer
tozir
2004 - 2008 F150
26
Jul 18, 2012 12:05 AM
Tanner2255
Jan 26, 2012 10:16 AM
Viper2F350dually
Nov 18, 2010 08:42 AM
OldBlue68
Jun 16, 2008 09:20 PM
Tom92F150
Offroad & 4x4
Aug 5, 2007 06:43 PM
