2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Dirt Curtains installed
Old 07-19-2018, 01:08 PM
AK-AlumADuty's Avatar
AK-AlumADuty
AK-AlumADuty is offline
Well, finally had some time off to get these fabbed/installed. Making them was easy- had a friend do it
Assembling & Installing- kind of a pain. I wanted a clean look so opted to mount them directly to my hitch. It’s 1/4” plate, so I decided to tap the holes I drilled. After measuring and aligning multiple times, I found the best spot. Securing them to mark the holes was fun (not). First hole drilled/tapped- looking good! Second hole, doing well- SNAP! Broke the tap (D@MN!). Oh, well, adapt and overcome. Whew- one side on. Moving onto the other side; same as the previous; one hole perfect, and broke yet another tap! Double D@MN! Finished both sides with hitch pins- yes, these are removable.
Install complete, a few cold ones to ease my troubles and wall-ah- dirt curtains
If I had to do it again, I’d probably weld the flanged section to the hitch rather than tapping.
Old 07-19-2018, 01:12 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Good job...use a good cutting fluid and tap slow with lots of backing up...or maybe you just needed a better quality tap. Are these for protecting a trailer?
Old 07-19-2018, 01:30 PM
AK-AlumADuty
Yeah, my TT has received more than it’s fair share or rock rings. I was going to buy some Rock Tamers, but 1) They don’t fit on a 3” hitch shank, & 2) They want an arm, a leg, & your first born for them bad boys. No thanks-
Old 07-19-2018, 02:56 PM
f350ktm's Avatar
f350ktm
f350ktm is offline
Nice work. That should give you good coverage.
Old 07-19-2018, 03:12 PM
Dr Matt's Avatar
Dr Matt
Dr Matt is offline
Nice! Wish I would hjave done something like this 10 years ago when I first bought my 5th wheel. Love to see them in person. Want to make me a set??? Extra wide or my dually.
Old 07-19-2018, 07:01 PM
ymsmiley's Avatar
ymsmiley
ymsmiley is offline
Those are pretty nice, especially for home made. And removable too!
Old 07-20-2018, 07:15 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,814 Likes on 1,367 Posts
Ah-ha! I thought you were the one who made the thread asking about those. Glad to see you had some made to your liking!
Old 07-20-2018, 08:56 AM
wb6anp's Avatar
wb6anp
wb6anp is offline
Wish some one made something like that that we could buy. I'd rather have those than the ones that go on the receivers when I have my tt attached.
Old 07-20-2018, 10:15 AM
xxxsherpa's Avatar
xxxsherpa
xxxsherpa is offline
Nice job AK.
Old 07-20-2018, 12:00 PM
AK-AlumADuty
I did inquire initially as I thought they were bought. I left a note for the owner whom replied and was nice enough to make me some- talk about a nice guy... I paid him for his services and bought the flaps at NAPA and mounted them. I like the look and it will keep rocks off my TT.
Old 07-20-2018, 04:34 PM
jimzpsd's Avatar
jimzpsd
jimzpsd is offline
Being a solid mount and only on one side, they need to be spring mounted (as seen on semi trucks) or support the other end some how. In time the single rigid mount will fail and it won't be pretty.
Old 07-21-2018, 01:45 PM
wrvond's Avatar
wrvond
wrvond is offline
I would love something like that on my truck!
Old 07-21-2018, 08:09 PM
stufarmer's Avatar
stufarmer
stufarmer is offline
I've been searching my options for the same thing. Those look great !
Old 07-24-2018, 08:53 AM
rb40racing's Avatar
rb40racing
rb40racing is offline
Old 07-24-2018, 04:04 PM
wrvond's Avatar
wrvond
wrvond is offline
Since I don't really have the resources to make my own, I went ahead and ordered a set of Rock Tamers from eTrailer.
Saw a bumper pull the other day that had a hole punched in the front from a hunk of metal thrown up by a rear tire. Hope these are substantial enough to stop that kind of projectile.
Quick Reply: Dirt Curtains installed
