cubic inch confusion
I wonder how effective it was to under-rate engines to try to fool insurance companies. Ford may have published a 290HP figure for the Boss 302, but it won't take a genius to figure out that it can make much more (~350HP) was the honest number. Presumably the insurance companies start charging much more when a car exceeds 300HP back then. So with today's cars advertising 400-700 HP, the insurance companies must be having orgasms.
the Chevy 427 with factory three two bbl carbs with mechanical lifter camshaft...
go 2 sizes larger on the main jets and advance the timing 8 degrees.. was an honest 500 hp...
but with crappy Tires... F-78-14.........Bias Ply..
super soft springs.. and shocks that was worthless...
control arms that could bend going backwards at 1/4 throttle...
I worked at the Chevy Dealership way back then.. and drove and wrenched on some of the fastest out of Chevy...
including the "Copo" cars. Yenko's..
I talked to my insurance co. (AAA in So Cal) about a Mustang GT back when they were only 420ish HP. Not too bad. Far from the highest rated car according to the dude on the phone.
Boss 302 and Z-28 were among the first to have the brakes and handling to (somewhat) match the power. (other than a Corvette, but I digress).
Anyway, if the OP hasn't got his answer by now he can come on and demand we get back to an answer.
so many changes in engines...
old.. heated intake manifold... from coolant,, BAD
many intakes today are Plastic... even less heat to fuel / air mixture...
friction and added weight.. from flat tappet camshaft design.. replaced by roller tappet.... replaced by overhead camshafts....
carburetors replaced by fuel injection...
computer controlled over points... including Timing... and as in the 6.2L adjustable camshaft timing... not just spark timing.
poor flow exhaust manifolds... to modern computer designed flow ...
No heat risers..
No heat risers..
wild_louie
12-23-2004 02:03 AM
