Engine upgrades?
Old Jul 16, 2018 | 03:09 PM
Owenage's Avatar
Owenage
Engine upgrades?
So I have a 2017 F-450 which is my daily driver as well as my tow rig. As I'm sure many of you are aware this has been a very very hot summer! Due to the temps and heavy towing, I'm considering options for better cooling performance. I noticed there doesn't seem to be any aftermarket options for radiators which would be where I would think to start. I have seen some options for the air to water intercooler and cold air intake, but I thought I would throw it out there and see if anyone has suggestions.
Cheers,
Joe
Old Jul 16, 2018 | 04:02 PM
mrgrayaz's Avatar
mrgrayaz
Are you actually getting overheat warnings or just worried about the high temps? These trucks run hot.
The new 2017 radiator is very complicated, with multiple cooling loops and thermostats, I would not be surprised if the aftermarket does not step up for a replacement, cheap or otherwise.....
Old Jul 16, 2018 | 04:08 PM
Drew_SD's Avatar
Drew_SD
+1 on this. High temps are normal on the 2017s, they actually operate much more efficient at higher temps. Changing the radiator would also be a nightmare job...
jc302x
Jan 24, 2019 08:31 PM
FrankGRUN
Feb 17, 2018 05:07 PM
The_Josh_Bear
May 3, 2016 03:01 PM
WillyB
Dec 5, 2005 08:19 AM
serczh1
13
Aug 2, 2003 02:17 PM
