Here's the problem, The odometer, Speedometer, Temp Gauge and the windshield wipers all do not work. The GEM has been changed to no avail. Not sure what to do next. Thought this would solve my problems. L
Any suggestions??
Do I need to change the cluster and the switch???
Does the GEM need to be programmed???
PLEASE HELP its raining and I need to get home…….J
Ummm the Fuses are fine....The diagram shows the Multifunction switch (Mazda World) or GEM (Ford World) controls many of the non fuctioning parts.....I wish it was a Fuse......
Woops, the fuse for the GEM was missing....Pulled it out before the removal of the old one....Double checked and sure enough not inplace......thanks for the suggestion....All working fine...
Originally posted by ForeTwenty Woops, the fuse for the GEM was missing....Pulled it out before the removal of the old one....Double checked and sure enough not inplace......thanks for the suggestion....All working fine...
