Fuel Leak
Old Jul 14, 2018 | 02:09 PM
NGH's Avatar
NGH
Fuel Leak
I noticed I have diesel leaking under the fuel tank. I filled up last Sunday and it’s been sitting since today when I noticed it. Any ideas what it could be from? 2017 F250 platinum CC.
Old Jul 14, 2018 | 03:23 PM
Can_Of_Worms's Avatar
Can_Of_Worms
I had the same problem with my 2015, check the filler hose, make sure they're on good and tight. My leak was coming from the fuel pump gasket, it had 2 gaskets on it from the factory which caused it to leak.
wb6anp's Avatar
wb6anp
If you topped it off, maybe the vent line is not sealed properly, or the filler neck.
Old Jul 14, 2018 | 05:36 PM
NGH's Avatar
NGH
Everything looks fine. Is it something I can keep an eye on and not top off anymore or go to dealer?
Old Jul 14, 2018 | 06:21 PM
wb6anp's Avatar
wb6anp
If you can't see anything on the vent or fuel filler, then Id say it is at the top of the tank maybe as said above the pump gasket, which means the tank needs to be dropped.So either a dealer visit, or don't top off. I have never been able to top off, too many cars waiting behind me in line.
Bearhugger1933
Mar 18, 2016 06:35 PM
Copedawg
19
Feb 7, 2011 09:10 PM
PocaFocus
Jan 23, 2010 01:59 PM
teederj2002
Jan 20, 2007 03:50 PM
