Stupid Mistake Towing - Should I worry??
I recently picked up my Redwood fifth-wheel from dealer service. My dealer was closing and I was trying to beat rush hour traffic and I hooked up and towed about 100 miles home. Upon getting home and unhitching I noticed my lubrication plate was missing from my king pin assembly. I'm guessing someone had swiped it while it was at my dealer and I didn't notice it was missing when I hitched up. I was stupid for not looking closer. Basically I towed 100 miles without any grease between the hitch (B&W Companion) and the baseplate. As far as I can tell there is no damage to either the hitch or the baseplate except for galling of the gray paint on the Companion hitch plate. There is no gouging on the metal of either the hitch plate or base plate. I didn't notice anything unusual when I was towing. I purchased a new lubrication plate. Should I be concerned going forward? Thank you.
The pinion shaft also has a grease zerk that can only be accessed from the bottom. I use wheel bearing grease for the pinion and ceramic brake grease on the jaws.
Yes I'm aware the jaws require lubrication and have applied the proper grease. B&W lubrication on the hitch plate too though. I'm glad the consensus is that I didn't damage my hitch plate or hitch.
Bigdon68
1999 to 2016 Super Duty
04-26-2016 09:07 AM
snowdog79
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
07-09-2013 08:40 AM
rebocardo
09-29-2004 11:21 AM
