filling/finishing a hole
on
Here's one of my back burner problems. 20 years or so ago I had a body man that cut in a third brake light in the cab. He had the light and worked out a nice mount inside the cab for it. I thought. Put the light on the shelf for later install. Fast forward to this year... put the light in the hole and wired it up and noticed this... Truck is in final paint. What can I use to fill this hole and paint... probably 3/16" wide and 1/2" high. Silicon won't work, won't take paint. Only needs to be pretty on the outside.. Found a product on amazon called 'thermomorph' a moldable plastic product that might do the filling and is paintable... suggestions ???
j
j
Find someone with a 3D printer to make a filler piece / bezel. Someone on here might even be able to do it for you. Our local UPS store has a 3D printer if you can create a file to upload. Do you know any engineering students? They would almost certainly have access to the software and a printer.
First off you are lucky to have chosen a solid color to paint your truck...much easier to match the paint.
How I would tackle this problem is to cut a piece of metal to fill the hole (not the entire 3rd light hole but just the opening that you need to fill). Using structural adhesive I would bond another piece of backing metal to the filler piece...the backer piece should be larger then the opening so that it can be bonded to the inner surface of the cab. I like to bond the two pieces together and allow to cure before fitting the filler into place on the cab...too many moving parts only makes things more difficult. When bonding the filler to the cab allow some of the adhesive to ooze out and fill in the gap between the patch and the cab body, this can be wiped off flush to minimize repair work later. Once the filler patch has been installed and the adhesive allowed to cure then the patch can be filled/sanded/primered and painted. If you are good with a brush then you could brush on the yellow and when dry color sand and buff...your choice. 3M08116/08115 adhesives will expand/contract at the same rate as the metal so they make a good bonding solution for jobs like this. Good luck...
Thermomorph isn't very durable. It re-softens in hot water.
First I would put a piece of cardboard up against the hole and then trace the hole with a Sharpie. The high-tech solution would be to scan that into a CAD file and then using polished SS use a plasma cutter to make a neat bezel. Low-tech would be, using the same traced template, make the bezel out of plastic like from a left over door panel or wood cutting it with a knife, skill saw, etc. You can then paint it any color you want.
