Why is my Engine is offset?
Old Jul 12, 2018 | 11:13 PM
Ikestang's Avatar
Ikestang
I’m curious to know why the engine seems to be offset to the passenger side on my 69 F100 a few inches? Is this to make clearance for clutch linkage and what not?
Old Jul 12, 2018 | 11:36 PM
TallPaul's Avatar
TallPaul
That is very strange. Is the pumpkin on the driveshaft also offset a few inches to the passenger side? I have had the inline six in a '77, a 84, and a '95 and never noticed the offset. A few inches is not much. Is it obvious or did it just seem like it and you measured to verify?
Old Jul 12, 2018 | 11:40 PM
Ikestang's Avatar
Ikestang
Yeah it’s noticable. My rear is offset. I have the equal length axle rear. I was mocking up my mounts for my crown Vic swap and confirmed its def offset. Kinda odd.
Old Jul 13, 2018 | 02:32 AM
mrpotatohead's Avatar
mrpotatohead
They're all like that. Look at your fan shroud closely.
Old Jul 13, 2018 | 07:05 AM
Coastal68's Avatar
Coastal68
Steering box clearance, too. The steering wheel is set at a slight angle also.
Old Jul 13, 2018 | 09:16 AM
orich's Avatar
orich
Off set to one side is okay as long as it's not tilled, then it could be a loose motor mounts or broken.
Orich
Old Jul 13, 2018 | 09:27 AM
RIPbiker13's Avatar
RIPbiker13
In my YouTube videos, I have mentioned this. In this picture you can clearly see the hole tunnel is offset to the passenger side, making the driver side floor pan larger. The engine mounts, everything is offset to the passenger side a couple inches. It makes room for the steering linkages and box, brakes, pedals, etc. It's normal, so long as you motor mounts are not broken.
Old Jul 13, 2018 | 10:05 AM
HIO Silver's Avatar
HIO Silver
Another reason the engine is offset is to allow the U-joints to work properly and avoid undue wear. See, if the driveline were in a straight line, then the U-joint bearings would wear in the same location all the time.
Old Jul 13, 2018 | 05:23 PM
CougarJohn's Avatar
CougarJohn
Most guys who drive this old iron are fatter than their wives. The offset balances the spring load.
Old Jul 13, 2018 | 05:49 PM
Ikestang's Avatar
Ikestang
LOL the most likely reason.
Old Jul 15, 2018 | 01:13 PM
fluff's Avatar
fluff
good answer! I noticed it when I put in buckets and set the console in
Old Jul 15, 2018 | 01:24 PM
Alex from GA's Avatar
Alex from GA
Why is mine offset, I weigh 140 lbs?
Old Jul 15, 2018 | 03:59 PM
CougarJohn's Avatar
CougarJohn
Put two concrete blocks on wifey's side and the steering pull will go away.
Ultra is good at aftermarket fabs to correct stuff like this. Maybe he can come up with a kit that allows transmission and motor mounts to be slid port and starboard to balance out these weight-distributions.
Truckie256
Dec 19, 2018 11:36 AM
Ikestang
Jul 15, 2018 09:59 AM
speedfreak78
Engine Swaps
Dec 29, 2016 12:25 PM
gofargogo
19
Jul 5, 2010 06:51 PM
FordEdselFanatic
Feb 22, 2009 04:13 PM
