Soft Brake Issue -- Possible Master Cylinder?
So this fire issue with the cruise switch mounted on the master cylinder is not an issue with this model year? That would explain why my MC looks completely different than everyone else. (no forward mounted sensor on top)
I'm going to try to find these plugs and do some more troubleshooting. Stay tuned...
That's the first bit of good news I've gotten since I started this project. Thanks for all the great info rla2005!
[QUOTE=rla2005;18091550]I have always found if the brake pedal stays firm and no dropping with the engine off the problem is vacuum based. If the pedal does drop and/or softens up the problem is hydraulic. If you can find plugs for the master cylinder ports you could remove the lines, plug the ports then see if the pedal drops. If it does, the master cylinder is bad. If not, the problem is further down stream.[/QUOT
Not to hijack the thread but Randy, my 91 pedal is mushy and I just did the pedal and it stays firm with engine off. Where would I check for the vacuum issue? Thanks Sandy
Butch(OH)
04-23-2008 05:14 PM
