If you were planning on running your truck hard....
what would be on your list to replace as preventative maintenance to avoid a breakdown?
Turbo?
EGR valve?
Ball joints?
Hubs?
Bearings?
Seals?
Serpentine belt?
Clutch/trans rebuild?
Is there anything worth upgrading short of deleting emissions?
Is there a good way to inspect leaf springs? I recall there being a red spray we used in my metal fab class in college that would highlight hairline cracks when we were forging and heat treating parts. Would something like that be worth spraying on the leaves around the mounts?
Of course, oil change, fuel filters, tires, and brakes but those I consider normal wear items.
Figure mileage between 150-175,000 to start with here.
Turbo?
EGR valve?
Ball joints?
Hubs?
Bearings?
Seals?
Serpentine belt?
To clarify - within the GCWR and GVWR ratings at or above 80% of daily mileage, up to 2500 miles per week/10,000 miles per month. In other words, within the capacity ratings the truck is designed for at a high mileage rate.
My theory is "something is going to go". I would rather down the truck before hand and replace something instead of killing the truck going down the road.
