propane distibuter conversion
Old Sep 22, 2003 | 12:44 AM
Arte's Avatar
Arte
Does anybody know how to recurve a distributer for a 1973 390 to run propane. The last conversion I did I had someone rip me of to the tune of $100.00 to do the dist. for me.
I understand it involves new springs and weights, but can it be that simple?
Any suggestions for a good how to site would be helpfull as the last conversion I did was about 12 yaers ago and I have lost all my books.
Old Oct 11, 2003 | 08:58 AM
dinosaurfan's Avatar
dinosaurfan
distributer recurve
Art, yeah, it is easy to change the springs and weights, but are you sure you want to ? Why do think that a propane burner needs a differant curve ? Howabout the curve you have now, but advance the initial timing to take advantage of the anti-knock ability of the propane ? Have you considered the engines compression ?....Doesn't propane like some more ? DF
Old Oct 14, 2003 | 07:23 PM
Arte's Avatar
Arte
sure propane love a 13:1 compression but its not required. My bagged out 300 cid ran great on propane and when I swapped it out It only had about 30-60 Lbs per cyl. The last V8 I put on propane without changing the curve damn near blew my exhaust system clean of the truck and almost gave the old guy behind me flash backs to WW II. T distributer definatly has to be re curved I just want to know if it is as simple as changeing the weights and springs? Or is there something else that needs to be done? I live in a very rural comunity of about 2000 peaple and nobody seems to know. I am a licenced mechanic so I know the responce I will get from another mechanic over a long distance phone call is going to be neglagable.
Old Oct 16, 2003 | 09:38 AM
gasman6674's Avatar
gasman6674
Propane is high octane so it likes a high intial advance 18degrees or so topping out at about 32degrees at 3000rpm. You can change the weights and springs but it works better to do it on a tester so you can double check/run the curve. If this engine is dual fuel you cannot change the curve but MSD has a sister division (Autotronics) that makes electronic "Dual Curves" so you can optimize for both fuels
Hope this helps
Old Oct 16, 2003 | 09:54 AM
Arte's Avatar
Arte
Thanks gasman this is exactly the info I was looking for, and no I am running or will be running strictly propane.
Old Oct 25, 2003 | 09:32 PM
Grey Ford's Avatar
Grey Ford
MSD has an alternative fuels division that can supply you with everything needed to do this properly.
I suggest the Programmable Timing Computer to adj. the timing manually. This replaces ALL of the springs and weights inside the distributor, and timing changes are made with ***** on the magic box.
I wish I would have known about this sooner.
