Exhaust Tip Question
Trying to decide on chrome pkg or no chrome pkg when i order. I was at a dealership looking at some 2018 trucks and they had a couple there that had aftermarket mods done to them.
One truck had MBRP black painted exhaust tips, At first I thought it was the whole exhaust but wasnt it was just the tips as it clearly had the set screws at the back end of the tips.
The mbrp tip covered all the holes on the stock tip which I think those holes are for some purpose of the exhaust system.
So couple of things
1. Ive done a search and haven't come up with if the holes in the stock pipe have a purpose, and if covering with another tip what the results would be in doing so.
2. Haven't found just the mbrp tips in black for a 2018
3. Did they use chrome mbrp tips and just paint them?
4. And has anyone just painted the stock tips a black color and have it look ok and hold up to the extreme temperature of a regen.
Thanks
So couple of things
Thanks
Yeah its a diesel. Did a little searching tonight. Its a 'Black Ops' edition truck from tuscany.
at about the 1.22 mark and again at the 2.18 mark
and this one at about the 1.28 mark
and from the tuscany site
Black Ops - tuscany
go to the F250 link and at the bottom under "standard exterior features' -- black powder coated exhaust tip
Black Ops - tuscany
https://www.youtube.com/watch?v=ypn_3OigvIo
https://www.youtube.com/watch?v=XwB7dnBl3bU
Black Ops - tuscany
Black Ops - tuscany
So questions remain.
1. Since they say they've been powder coated black, how do you suppose they would hold up the the extreme heat.
2. You suppose they would have any negative impact on the emissions stuff.
3. Has anyone tried just spraying their stock tips with some high heat rattle can stuff and have luck with it working.
In response to questions 1 and 2, the heat shouldn't be high enough at the tip to have any effect on the powder coat. The finish is baked on in an oven anyway. All of the emissions control is done in the "rocket ship" under the truck, so as long as you aren't removing any pipe or sensors, there will be zero effect on your emissions.
Can't really help you with the last question. Mine stay brown on the outside from dirt and mud at my place, and black on the inside from being deleted. I would think that with proper surface prep and a can of engine block paint or grill paint (VHT comes to mind), the rattle can would work.
LARIAT 85
01-09-2011 12:42 PM
