You don’t change it, you add it. Notice that the def gauge is showing 1/8 full. The tank holds 7.5 gallons and the truck gets 500-1000 miles per def gallon, depending upon load, etc. it’s part of the emissions control.
Youre dealer should have included this in the "orientation."
A more ideal situation would be to not let it get below a quarter of a tank, to prevent it from sucking in debris that may be in the tank or taking the truck into “limp” mode.
DEF is used constantly by the pickup, it is an expendable item. Need to refill it, just watch the gauge
