Hello. Question!
Old Jul 7, 2018 | 12:45 PM
Shockwave88's Avatar
Shockwave88
Hello. Question!
I have a question. This Pop up on the screen by the direction
What ia this Name:  photo402.jpg
Old Jul 7, 2018 | 12:52 PM
geereed's Avatar
geereed
Exhaust brake is on.
Old Jul 7, 2018 | 12:54 PM
crewzer's Avatar
crewzer
Lightbulb
I believe its a warning indicator for low or contaminated DEF.
HTH,
Jim / crewzer
Old Jul 7, 2018 | 01:02 PM
k7lvo's Avatar
k7lvo
Low def. See the same symbol in white below the def gauge at the top of the picture?
Old Jul 7, 2018 | 01:05 PM
Shockwave88
Okay now I see
Thanks. When do usually people change it
What the purpose of having def
Old Jul 7, 2018 | 01:10 PM
xxxsherpa's Avatar
xxxsherpa
Change it when you change the blinker fluid.
Old Jul 7, 2018 | 01:11 PM
k7lvo's Avatar
k7lvo
You don’t change it, you add it. Notice that the def gauge is showing 1/8 full. The tank holds 7.5 gallons and the truck gets 500-1000 miles per def gallon, depending upon load, etc. it’s part of the emissions control.
Youre dealer should have included this in the "orientation."
Old Jul 7, 2018 | 01:12 PM
k7lvo's Avatar
k7lvo
^^^^^That, too. 😂
Old Jul 7, 2018 | 01:14 PM
MPawelek's Avatar
MPawelek
You don’t Change the DEF, you add more to the DEF tank. Next to the diesel filler cap is a smaller blue cap. That is where the DEF is added.
Old Jul 7, 2018 | 01:24 PM
Shockwave88
When do you usually add
Old Jul 7, 2018 | 01:45 PM
harmanrk's Avatar
harmanrk
As with most things. When it's time. And since the light is on, its time.
Most refill the tank when they change the oil. As was said above, about 1000 miles per gallon on the DEF, so 7.5 gallons is 7500 miles.
Old Jul 7, 2018 | 01:59 PM
grngiant's Avatar
grngiant
I usually grease the muffler bearings at the same time I add blinker fluid.
Old Jul 7, 2018 | 09:07 PM
Cohlmeyer's Avatar
Cohlmeyer
A more ideal situation would be to not let it get below a quarter of a tank, to prevent it from sucking in debris that may be in the tank or taking the truck into “limp” mode.
DEF is used constantly by the pickup, it is an expendable item. Need to refill it, just watch the gauge
Old Jul 7, 2018 | 09:17 PM
CUScorpion's Avatar
CUScorpion
Is this for real? Buffoons like this, buying these trucks to look cool and say “ I’ve got a diesel” are part of the reason they’re so expensive.
Old Jul 7, 2018 | 09:25 PM
wfedwar's Avatar
wfedwar
Nice. I’m sure you were born knowing everything.
