Suspension component question.
Old Jul 7, 2018 | 10:48 AM
Trucklover22's Avatar
Trucklover22
Trailering
I have a 1979 F-350 4x4 truck that needs new rear spring hanger brackets. All the hanger brackets are in excellent condition on my 1978 F-250 4x4. Both trucks are Custom Trim trucks. Can I use the brackets from the 3/4 ton on my 1 ton since I do not plan on hauling a lot of weight as well as most aftermarket parts companies only carry lift kits for 3/4 ton and less trucks?
Old Jul 7, 2018 | 11:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Can I use the brackets from the 3/4 ton on my 1 ton?
Same!
EOTZ-5775-C (replaced D3TZ-5775-C & D8TZ-5775-B) .. Rear Spring REAR Hanger Bracket / Obsolete
1973/79 F250 2WD except Crew Cab // 1978 F250 2WD Crew Cab from serial number BC0,001 // 1979 F250 2WD Crew Cab.
1977 F250 4WD from serial number Y20,001 (not a High Boy) // 1978/79 F250 4WD // 1974/79 F350 Super Cab / 1979 F350 4WD
1980/96 F150/350 & Bronco // 1997 F250 H/D & F350.
Old Jul 8, 2018 | 09:49 AM
lafermedavid's Avatar
lafermedavid
ATS Leaf Springs and Suspension Parts by Auto and Truck Springs they will have what you need,they are heavy duty and well priced,keep your other truck in tack
Old Jul 8, 2018 | 11:21 AM
flatbedfordguy's Avatar
flatbedfordguy
Man! Those plow trucks really take a beating from the road salt!
Old Jul 8, 2018 | 02:56 PM
mark a.'s Avatar
mark a.
They are the same...but Bill already told you that. I think I'd look the underneath of that truck over real good if you were going to take it out on the road.
Old Jul 10, 2018 | 08:38 PM
Trucklover22
Trailering
I have already been under this truck as I was originally gonna use it as a parts truck for the F-250 but when I saw dual Dana 60's and a solid frame I plan on swapping the cab from my F-250 over as well as the Spring Hangers since right now money is extremely tight. The 250 has a broken front Dana 44 HD and the 250 has a better tranny for swap to the 350 plus the 250's cab is solid.
garryk6
Apr 21, 2018 06:32 AM
Kevin Malfy
May 20, 2016 09:17 PM
Sooper Camper
Jan 7, 2015 02:27 PM
BDawg171
Feb 20, 2010 06:22 PM
r2000f150
Feb 14, 2008 12:07 AM
