Starting Issues
If the engine really is overheating, it sounds like your thermostat may not be opening, and therefore you don't have any or enough coolant flowing through the block to cool things down.
The starting problem sounds like a rich or flooding condition compounded by the high temps vaporizing gas out of the float bowls.
First things first, take care of your engine and make sure it's not overheating. Overheating will kill any of the engines in these trucks, even if they may be reliable in other ways.
And best to get an after market temp gauge so you know what the engine is actually is.
If it running hot you may be getting vapour lock. Regardless you need to know if the engine is running hot or not.
Factory gauge? Lots of people diss on the factory set-up, but I have found mine to be very reliable. Just be aware the factory gauges are deliberately slow, to hide minor oscillations. Expect maybe a ten second delay for the gauges to respond, which is no big deal. Most gauges are like that, so don’t be alarmed.
I wonder if your temperature sender may be on its last legs, and is sending an inaccurate high signal when only slightly above normal. It’s perfectly normal for the coolant temperature to climb a little after shutdown, but typically we don’t see it because we’ve already turned off the ignition, and thus the power to the gauges.
Try this for some cheap and easy troubleshooting. Warm up the engine as normal. Shut it off, and then switch on the ignition again, but without starting the engine. I think the accessory position will even power the gauges, IIRC. Watch what the gauge does for ten or twenty minutes. Remember, it’s normal for the temperature to rise a little. But if you see it spike high, that would likely indicate a bad temperature sensor acting up.
This is the first thing to check and adjust the choke as needed to make sure it is open all the way when hot.
This is because of what is called heat soak. Motor is off but the metal is still hot and coolant is not flowing so the coolant picks up the heat from the metal. When you start the motor and hot coolant starts moving and hits the temp probe it shows a higher temp.
It should not spike. Because it is cheap I would replace the temp sender and if still not fixed or just do it, add an after market gauge so you know what is going on.
With knowing what is going on with the temp we can see if that is causing the hard start.
But there are a few things to check and do.
First check to make sure the choke is open all the way when motor is warm / hot like at the first stop. If not you need to adjust the choke so it is open all the way.
If the choke is open all the way climb up and look into the carb and see if fuel is leaking into the carb.
Now move the throttle you should see fuel squirt. If not we will have to do more digging why. Is it because fuel boiled out of the bowl (the fuel leak above) or bad pump?
Each carbed motor has it's own knack to start both cold & hot, thing is it takes time to fine what yours needs.
Don't pump the gas when trying to start when out. If you smell gas it could be from the pumping and flooding it.
When warm and if all is good you should not need to hit the gas just turn the key and it should start. Maybe press it down a little (1/4 way) and hold it there then try and start is all it should need.
Worst case hold pedal to floor till it starts but should not need to do that or pump.
Another test involves ice, a drag racers trick of sorts. Get a bag ice cubes, pull the air filter and plug any vacuum lines. Now go for your ride to the store when you stop put the bag of ice on top of the carb, try not to cover the black choke housing, close the hood and do your thing.
When you come out pull the ice off carb, note if choke is closed (hope not), close the hood, 1/4 down on pedal and start the motor. If it starts sooner than any time before carb could be heating up.
Dave ----
Go out and open the hood, take the airlcleaner off, and look for a large round black thing on the carb. This is your choke adjustment. See if it has rivets holding the round black piece on, or does it have screws. If it has rivets, they will need to be drilled out and screws put in their place. If you have to do this, you might as well get a rebuild kit, they usually have the screws included.
If you already have screws, take the truck out for a drive, let it sit, where you know it will give trouble starting. Instead of starting it, go out lift the hood, take the aircleaner off, and look at the choke. If it's shut or almost shut, that is a problem. Loosen those screws on the black round piece, and while holding the throttle halfway open(engine off) turn the black piece till the choke opens up. Let go of the throttle and tighten the black piece down. Then go in and see how it starts. If this fixes it, then you may have other problems on a cold morning start up, but we can address those if it comes up.
Also, what about the fan clutch? The manual states "With the engine cold (not run for at least one hour) and stopped, rotate fan by hand and feel motion. The fan should have some viscous drag and move smoothly through a full rotation. If the fan is not smooth, has no resistance, or does not turn at all, replace the fan clutch." I can't rotate mine without considerable force, and even with that, it doesn't spin it just moves as far as I can push it. I'll have to double check that mine is equipped with a fan clutch since it states (vehicles so equipped).
The carb does have a "clear flooded engine" mode, and if the choke happens to be closed, if you floor the gas pedal, there is a linkage that will force the choke door open some so the engine can get air. The choke system is fairly complex on these engines, a lot of little things to go wrong over the years which add up to a large mess to figure out. Many people just convert to a manual choke. Doing that it will work much like a older lawnmower or weedeater. You choke it when it's cold, and then manually turn it off when the engine warms up. And it will be much like the weedeater or lawnmower, you will have to learn how much choke the engine wants and when it wants it to keep it from stalling.
A few mile trip of stopping and turning it back on and it fired up no problems and stayed at 195 the whole time. I’m thinking since the passage to the tstat was so constricted there was no possible way the tstat could open.
Just curious, did the stock gauge behave itself once you got the coolant flow sorted out? In other words, it may have been reading correctly all this time and the coolant temperature really was spiking high shortly after start-up, just like the factory gauge showed.
