Mark V111 97-98
Old Jul 22, 2018 | 07:14 AM
Number4's Avatar
Number4
Variable spreed is how you avoid the high amperage inrush. Those Mark 8 fans have well over 100 amperes inrush. Same with crown Vic’s/town cars. Even though they may run at 20 amperes.
Variable speed or a soft start controller is really required. But finding one that will handle the inrush? Maybe those listed?
I went with a Flex a light controller that has a soft start, but at the time, the max fuse they offered was only 45 amp. I put in a 2001-2004 Mustang fan. It had an inrush of 60 amperes I believe and ran at 16 Amps. I tested what fuses would hold up and the 45 amp fuse was fine.
I also built a jig to test used fans and their output. I can tell you, people are misinformed on what fans put out how many CFM’s. I went back and forth with Dorman Tech on the specs for different fans, then tested them and some OE’s. Most didn’t even come close to the max specs.
Different forum...
https://www.explorerforum.com/forums...c-fans.417907/
Old Jul 22, 2018 | 11:34 AM
lafermedavid's Avatar
lafermedavid
Lincoln continental last year was 92,,,it came out of a Lincoln 97 Mark V111,seimen motor # different than fan shroud # says Ford made in Canada,,car was pretty complete that's all I know,blows a lot of air strong
Old Jul 22, 2018 | 11:35 AM
F-250 restorer's Avatar
F-250 restorer
Different forum.../
SEVERAL THINGS YOU WRITE ARE SIMPLY NOT THE TRUTH BUT RATHER INTERNET MYTH. From a stop to high speed jump, the MK8 only spikes from 48-53 amps. The following info I took from a reputable site:
Our testing showed the Mark VIII fan ran 26-28 amps on low, with a 37-40 amp startup spike. On high it had a draw of about 32-35 amps with a 48-53 amp startup spike.
The Taurus fan ran 24-26 amps on low, with a 32 amp startup spike
Then on high it used about 28-29 amps with a 40-45 amp startup spike.
I would also add that MANY people use these fans without PWM (pulse width modulation, or soft start controllers) without issue. I am one of them. A popular and very inexpensive control is the Volvo relay pack that starts your two speed fan in low, shuts off the low when/if the temp rises, and turns on the high speed. These can be had for $15-$20 in a j/y, or $55 new!!
**Keep in mind that the amps mentioned above are for a true MK8 fan. 90% of the people who call their fan an MK8 fan don't have a true one, but rather a Sable, Cougar, Taurus, Continental (not MK8), or Mustang fan with the wide blades but smaller motors than the mk8. Cheers.
Old Jul 22, 2018 | 02:14 PM
Number4's Avatar
Number4
The bigger a DC motor is, the greater it’s inrush would be. There is no way a Mark VIII fan has an inrush of only 48-53 amperes at startup. The ones I’ve personally tested maxed out my 100 amp gauge.
Running the Mark VIII and similar fans without an inrush limiter (or slow start) will put excessive wear on the relay contacts.
I believe the Volvo relays both run when max temp is reached, I’ve seen nothing that shows the first relay being disconnected.
Old Jul 29, 2018 | 08:12 PM
caliRangerXLT's Avatar
caliRangerXLT
Dave is this thing installed wired and running? The more I read about these the more problems I see. Gonna go check Steve's post now too find out how he handled the control power to fan control board...
Old Jul 30, 2018 | 04:55 AM
lafermedavid
just installed mine in my rad core,not in truck body yet ,tested it runs well,,,give ~FORD a write he has been running his for a while now.( researching auto cool )
Old Jul 30, 2018 | 10:28 AM
FORD~'s Avatar
FORD~
Yup for two years now without a hiccup. The model I bought will take up to 125 amps so it’s well with spec to handle a single automotive electric fan. I dig it but don’t begrudge anyone doing a non variable fan setup. One of the cool things about this forum is seeing all the ways people work on their rigs, both the simarities and differences. If I was running a cheapie PWM controller though I’d probably use a solid state relay to be safe.
littleapple
May 2, 2017 12:19 PM
RKCORPS25
Nov 5, 2013 05:59 AM
autotheft686
6.4L Power Stroke Diesel
Jul 19, 2011 04:21 PM
fmc400
General Automotive Discussion
Jan 10, 2008 09:28 PM
Kikwear
1978 - 1996 Big Bronco
Oct 6, 2003 10:36 PM
