Ranger gear ratio
Old Sep 21, 2003 | 09:18 PM
eyesman's Avatar
eyesman
Question Ranger gear ratio
I have an '85 Ranger V8 conversion. The tag on the rearend cover has 2 lines of numbers... the top line is 68988... the bottom line is 8 45 A75 5D26... Can anyone tell me what ratio this axle is? It is the stock axle from the Ranger. I haven't found an info site yet that identifies this type of tag.
Any help appreciated.
Thanks,
B
Old Sep 21, 2003 | 10:24 PM
ecarter50's Avatar
ecarter50
Ranger gear ratio
If you look closer at the tag the 8 in bottom row is probably a 3. You probably have 3.54 ratio 7.5" open axle. The axle code on your drivers door pillar should be 84.
