Aerostar Ford Aerostar
Question on front shafts
Old Sep 21, 2003 | 08:48 PM
68torino's Avatar
68torino
I get a bit of a vibrational growl(felt more than heard) from the right front shaft on my '91 E4WD Shorty. This is during 1\2 to 3\4 deflection from going over severe bumps above 55. I checked the shaft for play and I can twist\wiggle it enough to feel but not see. It looks like the left side was changed as it has a chrome center, the right dosen't, the left has just a ghost of play(I'm guessing just gear play). I'm guessing time to replace the shaft. It dosen't look to tough, but are there anything special for tools needed? What kind of time frame is typical? I don't have agarage, so I work outside.
Old Sep 22, 2003 | 09:59 AM
aerocolorado's Avatar
aerocolorado
Takes around 2-3 hours time, perhaps more for the first time. You will need a new axle nut and a 30mm deepwell socket to remove the old one. A long (24") breaker bar and torque wrench capable of 175+ ft/lbs is necessary. Some parts stores have these for "loan". The axle nut is a dealer only item at this time.
There are several posts on this forum with all the details and tips on this proceedure.
Old Sep 22, 2003 | 11:19 AM
68torino's Avatar
68torino
Thumbs up Question on front shafts
Thanks Aerocolorado, looks like I get to buy more tools which of course I like doing. I have read some of the other post, dosen't appear to be to tough a job.
