Console connector pinout Help
Old Jul 3, 2018 | 08:00 PM
Old_Duck's Avatar
Old_Duck
Trying to work out the pins/ wire colors on the connector that was connected to my jump seat, that I am swapping out for a console
My truck is a 2018 F250 XL/STX. The following pins and wire colors are on the truck side of the connector, and the only two currently used are pins 8 and 16. The descriptions are from what I found on other posts and are based on the wire color not pin number.
Hoping someone can confirm what is listed below and hopefully fill in the blank on pins 18 and 19
  • Pin #3 - YE/VT - Inverter LED Indicator +
  • Pin #5 - BU/BN - Inverter LED Indicator -
  • Pin #6 - YE/GN - Relay - Battery Saver (Switch Off Interior Lighting)
  • Pin #8 - GY/VT - Fuse #68 (Console PowerPoint)
  • Pin #11 - OG/WH - Inverter AC (AC B)
  • Pin #16 - BK/WH - Ground
  • Pin #18 - VT - ?
  • Pin #19 - GN/OR - ?
  • Pin #21 - OG/GN - Inverter AC (AC A)
Thanks for the help
Old Jul 4, 2018 | 11:16 PM
jonathanjr1's Avatar
jonathanjr1
  • Pin #18 - VT - ?
Thanks for the help
i believe pins 18 and 19 are for the antenna on push button start trucks.
Old Jul 5, 2018 | 04:24 AM
Old_Duck's Avatar
Old_Duck
Jonathanjr1
Thanks . I had not thought of that. Was thinking they might be for USB charge only ports
Thanks again
Old Jul 5, 2018 | 11:46 AM
MNSuper's Avatar
MNSuper
Do you know how to remove the pins and change where they are in the plug? I encountered this same problem. Switched from jump seat to console and none of the wires match even though the plug plugs in. I've considered buying a wiring harness but switching the pins would be cheaper.
Old Jul 5, 2018 | 12:16 PM
jonathanjr1
it's not hard but you need to make shure your moving the right wires around.
here is a video showing how it's done
https://youtu.be/PB6KcLSCAGU
Old Jul 5, 2018 | 01:25 PM
Old_Duck's Avatar
Old_Duck
That's the video I say. already have the pins out of the connector. Just waiting on the parts for the dash to start putting the console in and the service manual I ordered to hopefully confirm connections.
TheLex
Jun 4, 2018 11:36 AM
Auger Hekla
Aug 19, 2017 02:58 PM
Usmc6.0
May 31, 2017 01:22 PM
jasonodsky
Dec 22, 2010 10:07 PM
pappy19
Appearance & Dress-Up
May 18, 2010 10:27 PM
