Identification help
Old Jul 1, 2018 | 05:29 PM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
Identification help
What is this glass bowl called on the carb? I am trying to look for a new gasket because it leaks. I can’t seem to find it because I don’t know what it’s called. I looes up fuel systems and carb parts.
Old Jul 1, 2018 | 05:33 PM
76-5.0's Avatar
76-5.0
Float Bowl gasket.
Old Jul 1, 2018 | 05:34 PM
52 Merc's Avatar
52 Merc
That would be the carburetor fuel bowl, or float bowl, depending on who you ask. Either description should be able to get you a bowl gasket.
Old Jul 1, 2018 | 06:31 PM
HVFDFIREFIGHTER1618
How do I tell what engine I have? I know it’s a 6 cyclinder. 215? 223? I’m trying to find the right size oil filter.
Old Jul 1, 2018 | 10:17 PM
Mixer man's Avatar
Mixer man
That would be the 215. The 223 has the breather on the front of the valve cover.
Old Jul 1, 2018 | 10:55 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Both the front breather and middle breather valve covers were used on 215 engines. The Jan. 1952 edition of the Chassis Catalog shows both. The easiest ways to tell a 215 from a 223 are by the distributor locations and by the shape of each exhaust manifold. Agree the pictured engine is a 215.
The Holley 1904 glass bowl gaskets are available in the rebuild kits available from Carpenter and others. Finding just the gaskets might be a challenge.
The cartridge oil filter (stock, not spin on) is a Fram CH6PL. Stu
Old Jul 1, 2018 | 11:54 PM
HVFDFIREFIGHTER1618
Thank you.
if I unbolt the fuel pump and off to clean or replace, do I need to drain oil from engine first?
When changing the oil, what weight oil should I use and how much?
Number4
19
Apr 2, 2019 09:22 PM
HVFDFIREFIGHTER1618
18
Aug 1, 2018 08:56 PM
acl9865
22
May 26, 2018 08:44 PM
7636074460
Apr 18, 2013 07:08 PM
mOROTBREATH
May 24, 2010 10:27 AM
