CAI
Old Jun 25, 2018 | 08:57 PM
Hank85713's Avatar
Hank85713
CAI
we have E450 based rv and the air intake system is really convoluted under the hood. Has anyone found a good CAI replacement for the intake air. Really think it will improve performance as would a good free flow muffler. Gibson has the muffler, just need to find a air intake, even if it keeps the stock air filter and just replaces the intake nozzle.
Old Jun 26, 2018 | 07:47 AM
wirelessengineer's Avatar
wirelessengineer
Cold Air Intakes are touted as The Great Thing by those who sell them. Many auto magazines have tested them, and the dyno says they don't do much.
Old Jun 26, 2018 | 08:16 AM
Clubwagon's Avatar
Clubwagon
It would help if we knew what model year and engine you have.
As noted above, CAI are more hype than help in most cases. Just depends on the application and the vendor. Banks has some good stuff for vans but most of the stuff is crap.
I had the best results by replacing the OE muffler with a good aftermarket, low restriction, unit.
Old Jun 26, 2018 | 08:33 AM
Hank85713's Avatar
Hank85713
club wagon, thats why I asked. Yes some CAI are junk some are not. Not looking for hp gains just better performance abd a cai plus muffler well thats it. As to being junk there have been some articles just the opposite. Recent motorhome article recommended improving the intake, but it was on a 3 valve v10 and the performance improvement was worth the effort.
As to the my its a 2012 (11 running gear) E450, 6.8. Small snorkel on top of radiator and many turns to the air filter.
Old Jun 29, 2018 | 08:25 PM
wirelessengineer
The problem isn't that some are junk. The problem is they don't work. The air intake is rarely the choke point of performance. It would have to be a very poorly designed factory intake for that to be the case. Can it happen? Possibly, but show me a test done with instrumentation producing hard numbers, not just subjective reports from test driving.
Old Jun 29, 2018 | 08:49 PM
m-chan68's Avatar
m-chan68
Gents, let's remember what any internal combustion engine is, a glorified air pump at the end of the day. The more air in, the more air out, the better the performance. To reap the benefits of improved air flow, requires improving it on ALL fronts. This means not only unrestricted air in (without compromising filtration quality of course) and unrestricted air out, but the tools needed to move the greater air flow in the first place, namely the cam profile as well as the size of the intake and exhaust ports in the cylinder heads. I'm fairly certain that the engineers at Ford Motor Company did a fine job in this department on a power plant that dates as far back as 1997 with minimal changes. Having said that, as others above have already posted, you will achieve little to no benefit attempting to source out an aftermarket intake for this. How much more power do you need to move an RV?
Old Jun 29, 2018 | 11:32 PM
blageurt's Avatar
blageurt
Spend your money on a good shift kit and maybe upgrade the TC TransGo and then get a Tune from these guys https://5startuning.com/got-a-v10-rv/ might be a better way to go....Good Luck
Old Jul 1, 2018 | 06:53 PM
wirelessengineer
More, of course. Always more.
Your post is right on target. People don't seem to understand that it is a system, not a collection of parts that happen to work together.
Magic bolt-on HP doodads rarely do enough to be worth the trouble, let alone the money.
Old Jul 6, 2018 | 01:01 AM
econovanfan1's Avatar
econovanfan1
Just remember that not only do dyno tests prove that CAI provides very little to no improvement, MANY of them actually DECREASED the performance of a factory tuned engine …… and the same was true with a low-restriction muffler. Keeping your vehicle well maintained and using quality fluids and gasoline will provide your best performance, otherwise it is a long, hard road replacing parts and getting the vehicle professionally "tuned" to gain appreciable power.
BadAzzFordF250
Mar 14, 2023 03:55 PM
4X4 IN REFUGIO
6.4L Power Stroke Diesel
Jun 6, 2012 04:17 PM
offroad17
Air Intakes, Air Filters & Ram Air
Nov 7, 2008 12:16 PM
NY-Ford-Lifer
2004 - 2008 F150
17
Apr 11, 2005 10:57 PM
tc1
1997 - 2003 F150
Dec 17, 2000 06:38 PM
