2019 Potential Order - Height Questions
Old Jun 30, 2018 | 04:24 PM
scottjima's Avatar
scottjima
Question 2019 Potential Order - Height Questions
I currently have a 2011 F-350 CCSB 4z4 6.7 w/ 20" wheels. I am considering ordering a 2019 F-350 Lariat Ultimate in the same configuration that I currently have. I have a couple of questions. I have extensively searched...
1. My current 2011 F-350 clears the garage door by about 1.5" to 2". If I order the truck with without the snow-plow prep or HD front suspension, do you think it will fit? The numbers Ford quotes are all over the place and it is very hard to measure one. The dealer is 40 miles away and they don't have a 350 CCSB w/out the snow plow prep package to try.
2. If I order the cab marker lights, does this add height? I can't tell if they mount to the high point of the cab or if there is a bit of a curve down where they attach.
3. Thoughts on the adaptive steering?
Old Jun 30, 2018 | 05:07 PM
xxxsherpa's Avatar
xxxsherpa
The rear of the cab is the highest point even with cab lights. My stock truck sits 3/4" below 7', it is a 2017 f350 with snowplow front springs.
Old Jun 30, 2018 | 06:31 PM
davew593's Avatar
davew593
I have the same set up and am about 1 inch below my seven foot door.
I had same concerns when buying mine a few months ago. I measured my door and the truck which was about 50 miles away, measured the truck again and again and rolled the dice. Was very pleased to have plenty of clearance.
Old Jun 30, 2018 | 06:53 PM
CBEllis's Avatar
CBEllis
Mine clears the 7’ car wash in town but I scrapped a 7’2” parking garage in Dallas this week...had to reverse out of that one. Luckily, I have 8’ doors at the house.
Old Jul 1, 2018 | 07:17 AM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
My F-350 ccsb with the 18 inch wheels measures a hair under 84 inches. The clearance lights will not be an issue unless you put a leveling kit on it, as the highest point on the truck is the very rear of the cab.
hikeril
6.7L Power Stroke Diesel
May 4, 2015 11:30 AM
bryced15
Feb 20, 2011 09:57 AM
craig houser
Oct 13, 2010 10:00 PM
H2oSprayer
Feb 1, 2009 08:22 AM
Paul K
General Diesel Discussion
15
Jun 13, 2007 08:04 PM
