turbo change need help quick
Old Sep 21, 2003 | 05:52 PM
MIKE8349's Avatar
MIKE8349
Question turbo change need help quick
i have a 96 psd im changing the turbo and need and easy way to remove it. the truck is also geting repainted and it needs to be done tomarrow. please help !!!!!!!!
mike
Old Sep 22, 2003 | 11:07 AM
bricot's Avatar
bricot
Haven't taken mine off ... yet ... planning on getting the banks turbo upgrade.
I picked up a Chiltons manual, has decent instructions for most thing, you may go get one. I wouldn't be able to look until tonight which sounds like it would be too late.
Old Sep 22, 2003 | 04:32 PM
MIKE8349's Avatar
MIKE8349
still didnt get it done and tomrrow is my last chance all help apricated.
thanks
Old Sep 22, 2003 | 07:55 PM
bricot's Avatar
bricot
Ok, here goes only have a few minutes.
1. disconnect negative battery cable
2.Remove the 2 air intake assembly bolts, clamps at the turbo, crankcase breather assmbly, engine air cleaner, and air intake tube and hoses
3. Remove the exhaust outlet clamp from the turbo
4. remove engine charge exhaust pipe bolt from the transmission, if equipped
5. remove bolts and nuts from the catalytic convert to engine charge exhaust pipe if equipped
6. loosen 2 bolts retaining the turbo exhaust inlet pipe to the left exhaust manifold
7. for auto tranny, remove the bolts retaining the left turbo exhaust inlet pipe to the turbo exhaust inlet adapter
8. loosen the 2 bolts retaining the right turbo exhaust inlet pipe to the turbo exhaust inlet adapter
9. remove the lower bolt retaining the right turbo exhaust inlet pipe to the turbo exhaust inlet adapter
10. for auto tranny, remove the uper bolts retaining the right and left turbo exhaust inlet pipes to the turbo exhaust inlet adapter
11. remove the right engine lift hook and bolt
12. losen the air inlet hose clamp at the turbo, disconnect the hose and lay it aside
13. for auto tranny, loosen the 4 intake manifold hose clamps and 1 clamp retaining the compressor manifold to the turbo. Remove the compressor manifold
14. remove the 4 bolts retaining the turbo pedestal assembly to the cylinder block
15. Remove the rubo assembly and detach all electrical connectors
16 remove the galley O-rings
Sorry about typo's....
Old Sep 23, 2003 | 05:27 PM
bricot's Avatar
bricot
Were you able to do it?
Old Sep 24, 2003 | 09:30 AM
MIKE8349's Avatar
MIKE8349
nope couldnt get it. going to wait till after is done and hope not to scrach the paint.
