Fuel pump
Old Jun 29, 2018 | 10:28 PM
Scrabbit's Avatar
Scrabbit
Fuel pump
i just got a 78 351m f250.it has been sitting for a few years, guy I got it from cleaned carb. My mechanical fuel pump started weeping gas so I put a new one on and now the truck isn’t running right. When it was leaking I could drive er pretty descent around yard. Now it will idle but if I give er to much gas it’ll die. What’s my next step?
Old Jun 30, 2018 | 09:52 AM
flatbedfordguy's Avatar
flatbedfordguy
Is the fuel pumps arm below the cam eccentric, where it's supposed to be. Or above the cam eccentric?
Old Jun 30, 2018 | 10:25 AM
DB429SCJ's Avatar
DB429SCJ
Check fuel filter. If its ok, check line from pump back to the tank to make sure it's not clogged or sucking air. If that's ok, take the fuel line off of the carb,, stick the end into a plastic bottle and crank the engine.You should get good spurts of fuel. If not, you may have a defective pump.
Old Jun 30, 2018 | 11:31 AM
Scrabbit's Avatar
Scrabbit
Thanks
had gunk in the line n plugged the new filter. Blew er out, filled a glass jar with gas coming out of line going to carb n now she’s running good
Mikey G
Aug 12, 2016 10:00 PM
FearTheEfficiency
Aug 27, 2015 03:50 AM
Clay Hibbs
Jul 24, 2012 12:41 PM
keyul
May 15, 2011 10:38 AM
JeremyKS
May 30, 2007 07:11 PM
