Engine died while driving
Old Jun 28, 2018 | 07:20 PM
MrBonez's Avatar
MrBonez
Alright I find myself here again needing some input...! Today while driving my 99 f150 4x4 5 speed (4.6) I felt a slight miss while in 4th gear and didn't think much about it until it happened again! Except this time it felt like i was running out of gas but I had a half tank. So i was good on gas! I thought well I'll shift to 3rd because I would be approaching a stop sign soon. By the time I got to the stop sign I was struggling to keep it up to idle and as soon as I pulled out onto the road the engine completely shut down and I was lucky enough to get it off the road at an abandoned store. I started it back up and it shut down again! So to make this short I waited about 10 mins crunk it up again and it was back to normal! I was very fortunate that I was only a mile and a half from where I live! It's parked and I'm afraid to go anywhere in it now.! I'd like to hear some thoughts as to what this could be?
Old Jun 30, 2018 | 05:45 AM
Im50fast's Avatar
Im50fast
Gotta check the vitals. Fuel, compression, spark, and engine codes.
Compression and spark don’t seem likely based on your description. Fuel problems are more common.
Get you a fuel pressure gauge (not a cheap junk unit) and report back.
do you have a Check engine Light? Must follow that.
Another suspected problem could be backpressure in the exhaust due to failed catalytic converter(s).
also I suspect vacuum leak.
Old Jul 2, 2018 | 01:32 PM
MrBonez's Avatar
MrBonez
This is what I found while looking at the fuel regulator.! A hole chewed out on the fuel regulator vacuum hose by a rodent! Will this cause the engine to shut down? I'm thinking it will lol... See the attached pic
Old Jul 2, 2018 | 01:38 PM
Scratcha's Avatar
Scratcha
"Them...there varmints will do it every time!"
It amazes me what they'll try to eat! They also love the insulation on electrical/electronic equipment wiring also. Crazy!
That's probably the culprit. Some good duct tape will help "in a Pinch" till you get to the auto parts store.
Old Jul 2, 2018 | 02:02 PM
MrBonez's Avatar
MrBonez
I'm hoping that's the culprit... I just went to advance and purchased a rubber elbow and installed it! Man I just got it out of the shop not even 2 weeks ago and had a slave/master cylinder installed and then it shut down on me last week! So some test driving is the plan now
Old Jul 16, 2018 | 09:54 AM
MrBonez's Avatar
MrBonez
Update...! After finding the vacuum leak and then fixing it the problem has returned! Except this time it's a bit worse. After it gets to running temps the engine will idle for 5 mins or so and then it starts to too splutter and shuts down! It will not crank back up until a couple mins have gone by and then it will shut back down again after about 5 mins of idling... this morning it idle good without shuting down but i belive it was only because i didnt drive it to running temps? It has been throwing a PO420 code for quite sometime so this leaves me think the cats are gone
mybadford
Nov 16, 2018 09:25 AM
HillBillyBuddha
Modular V8 (4.6L, 5.4L)
Jun 27, 2018 08:38 PM
DBGrif91
19
Aug 11, 2013 07:31 AM
Eaglefx
Nov 16, 2008 10:54 AM
Woodtroll
4 Cylinder Engines
May 3, 2007 08:49 AM
