Fuel Pump Wiring Issues
Old Jun 28, 2018 | 07:12 PM
danjford's Avatar
danjford
Hi guys, I'm new to the forum.
Just bought an '86 F150 with the 302 efi in it. Previous owner said the fuel pump quit getting power all of a sudden and he thought it might be the ICM. I figured it wouldn't be too hard to diagnose, so went ahead and took it. When I got it home and started working on it, I noticed he had apparently cut the hot wire coming from the fuel pump at some point and stuffed it up under the coolant reservoir. According to the wiring diagram I have, It should run right to the inertia switch, however the switch has two yellow wires coming from it, both wired into the fuel pump relay. Am I missing something? I think I might just get a cheap switch and rewire the whole circuit. If that's the case, I need to know where the eec relay is but cant find it for the life of me. Any suggestions? I'll post pictures tomorrow when it's not storming outside Thanks in advance!
Old Jun 29, 2018 | 02:15 PM
Franklin2's Avatar
Franklin2
In this link is everything you need to know, you are lucky it's online. It will tell you your fuel pump circuit/wiring, and it also tells you locations for everything with pictures. Write back in if you need help reading it.
1986 EVTM - ???Gary's Garagemahal
Lead Head
1983 - 2012 Ranger & B-Series
Nov 12, 2008 03:50 PM
downsouthhustler
Bronco II
Apr 13, 2006 10:10 PM
89fordf150owner
13
Jan 5, 2006 05:58 PM
mrcarter
Bronco II
Nov 17, 2004 11:58 PM
Joe, IN
Bronco II
Oct 11, 2003 08:09 AM
