Bronco II Ford Bronco II
bronco blues
Old Apr 12, 2006 | 05:18 PM
downsouthhustler's Avatar
downsouthhustler
Question bronco blues
will some 1 please help me ? i have a 88 broncoII that i have just put a new motor in(2.9) and i can't get the fuel pump to work. and its a new pump and i even tested it so i know it works.. please help me or tell me if i could run a wire that will turn it on when the key switch is on.
Old Apr 12, 2006 | 05:31 PM
mrshorty's Avatar
mrshorty
Do you have a wiring diagram? The fuel pump wiring isn't too complicated: B+ -> relay -> inertia switch -> fuel pump -> B-. Relay is opened/closed by the main computer. I suspect either you forgot to hook something up, or there's some other break in the circuit. In either case, it shouldn't be too hard to track down with a voltmeter and a wiring diagram.
Old Apr 12, 2006 | 05:43 PM
downsouthhustler
i checked the inertia switch and it was not tripped. i tripped it then reset it also checked where the fuel pump plugs in with a volt meter it has power..
Old Apr 13, 2006 | 10:25 AM
mrshorty's Avatar
mrshorty
Is the ground connected? Good ground at the chassis?
Old Apr 13, 2006 | 10:32 AM
Aggie05's Avatar
Aggie05
i would try shortys advice, ive had some trouble with ground issues check that first.
Old Apr 13, 2006 | 03:39 PM
Desert Dog's Avatar
Desert Dog
Fuel Pump
Check for voltage at the wires were it goes into the fuel pump,I had a short at the rear of the frame above the fuel tank and also a fualty connection at the top of the tank wire connector.
Old Apr 13, 2006 | 08:52 PM
fl1a's Avatar
fl1a
If you should need a wiring diagram, the HAYES manual has diagrams for all the years
it covers. Good Luck.
Old Apr 13, 2006 | 10:10 PM
OSin86's Avatar
OSin86
Also Auto Zone online offers Hayes style wiring diagrams for free.
