4R70W planetary gear set to carrier
Old 06-28-2018, 05:38 PM
z 97ford1's Avatar
z 97ford1
z 97ford1 is offline
Is there a MINIMUM end play spec for the planetary gear set to carrier wall?
I'm rebuilding my 1997 trans and am hearing the end play max is .030. Anymore than that and I'm hearing the ENTIRE planetary assembly is to be REPLACED.
I'm getting as much as .050.
Old 06-29-2018, 10:50 AM
jk080's Avatar
jk080
jk080 is online now
Transmission Rebuilder
We build these all the time, I wouldn't worry about that clearance, these never fail due to that, I would just run it you won't have any issues.
Old 07-02-2018, 04:07 PM
z 97ford1's Avatar
z 97ford1
Ok, I'll reuse it. Actually, one gear clearance is over .050 but the other right next to it is under .03 so maybe you don't have to measure the one.
underthebridgejim
15
07-16-2015 09:46 AM
r___r
Fifth Wheel & Gooseneck RV Towing
18
10-13-2014 01:13 AM
4 eyes f600
09-01-2012 09:10 PM
nat13_3
09-18-2009 06:29 PM
abelmoreno
09-13-2009 10:33 PM
Quick Reply: 4R70W planetary gear set to carrier
