C-6 upshift
Old Jun 30, 2018 | 12:01 PM
Peter A.'s Avatar
Peter A.
Installed modulator and new vacuum line this a.m. No difference at all. Even though the old modulator would not hold a vacuum. Got very pissed off, threw the VRV adjustment directions away, and hit the road with tools and a chair in hand. I set the VRV position roughly in the middle with engine off. After the third eyeball adjustment, it shifts the way it should. I can finally say that the engine swap from 6.9 to 7.3 finished. Much thanks to all of you for your input and advise.
Peter
Old Jun 30, 2018 | 02:12 PM
tjc transport's Avatar
tjc transport
i ain't rite
yea, i went nuts with them silly directions. set to blah blah pressure. snap the throttle open closed 5 times should hold blah blah pressure. restart engine..................give me a break!!<br />i set it all the wat one way and turned it back until it worked.<br />then when the trans finally died i replaced it but it came with 4 different modulators. i slapped the green one in and put the rest on the shelf.<br />i bet that has gotten less than 50,000 miles on it in 14 years.
Michael Chappell
Mar 19, 2019 12:17 PM
cornbinder
May 24, 2010 10:56 PM
65steelstallion
Apr 29, 2008 08:13 AM
michigandrake
Sep 22, 2006 09:06 AM
