Po4DB Code
Old Jun 27, 2018 | 02:36 PM
Superdutytrain's Avatar
Superdutytrain
Po4DB Code
Check engine light came on showing the code:
PO4DB . Cant find it in the listings??
Old Jun 27, 2018 | 03:00 PM
nuctrooper's Avatar
nuctrooper
Copied from another user. The "o" is actually a zero:
The 6.7L diesel engine has a crankcase ventilation separator mounted on the driver side rocker cover, with a tube connecting the separator to the fresh air inlet of the turbocharger. The tube on the separator side has a tamper proof collar installed and is plastic welded to the separator. On the fresh air inlet side, a hall effect sensor is present, to detect connection to the inlet casting assembly. The tube cannot be disconnected on the separator side, and if it is disconnected from the inlet casting, a P04DB code is set, as sensor output drops below a calibrated threshold. There are also circuit range checks, P04E2 and P04E3 to detect shorts to ground, or short to battery/disconnected sensor, respectively.
Crankcase Ventilation Monitor
DTCs
P04DB – Crankcase Ventilation System Disconnected
P04E2 – Crankcase Ventilation Hose Connection Sensor Circuit Low
P04E3 – Crankcase Ventilation Hose Connection Sensor Circuit High
Monitor Execution
Once per driving cycle – P04DB
Continuous – P04E2, P04E3
Monitor Sequence None
Sensors OK P04DB - CVM (P04E2, P04E3)
Typical Monitoring Duration 2 sec
Old Jun 27, 2018 | 04:12 PM
Just Strokin's Avatar
Just Strokin
There is a FSA that extends the warranty for the CCV. Contact your dealer for repair.
Old Jun 28, 2018 | 04:19 PM
Superdutytrain
Thank you sir. I will talk to my dealer. The light has gone out but will call dealer anyway. Truck only has 35K miles on it.
Old Jun 28, 2018 | 04:23 PM
Superdutytrain
Thanks I will check with my dealer for repair. Only 35K on truck.
Old Jun 30, 2018 | 08:31 PM
azking_Ranch's Avatar
azking_Ranch
Just had my 2015 serviced for this code, dealer had to replace the CCV unit since the sensor is part of the no removable hose.
Old Oct 27, 2019 | 09:36 PM
Cole Spillar's Avatar
Cole Spillar
How much did it cost to replace at the dealership?
tracyclifton
6.7L Power Stroke Diesel
22
Aug 21, 2021 08:31 PM
draboo
Jan 20, 2019 01:04 PM
Kipdula
Dec 27, 2018 06:13 PM
PDC1
Aug 27, 2018 07:43 PM
Superdutytrain
Jun 27, 2018 04:10 PM
