Drive Line reinstalling problem.
Old Jun 27, 2018 | 02:05 PM
Jake McCracken's Avatar
Jake McCracken
Hi I have a 96 f250 4x4 and i took off the drive shaft and putting it back on has been a pain. I have the splines hooked up but the shaft and boot won’t slide forward any suggestions?
Old Jun 27, 2018 | 02:46 PM
EQCMCAT's Avatar
EQCMCAT
If you can without destroying the one clamp, remove it to allow you to move the boot enabling possible eyes on visibility alignment. Next, if you haven't yet, try using a light application of chassis grease on both the receiving and input ends. Then you might have to use a rubber mallet and tap on the rear of the drive shaft. If you resort to using a sledge hammer, use a piece of wood (3/4" plywood or a 2" x 6") between the hammer head and drive shaft to avoid any chance of destroying the drive shaft, but don't over do the amount of striking force, be gentle.
Ikestang
Oct 22, 2018 06:08 PM
aceltx09
Aug 10, 2010 07:30 PM
jpjohnsr
Dec 5, 2009 05:27 PM
oldcoupe42
Mar 6, 2004 07:04 PM
