5.0L Oil Use Between Changes
Old Jun 26, 2018 | 07:33 PM
smokewagun's Avatar
smokewagun
Interesting read on other post regarding oil prompted this.... I changed my oil for the first time at about 1600 miles. I put the 8.8 quarts specified in my 5.0L, and after 1,600 miles of interstate driving it was down a quart. I can't imagine it's burning that much, nor have I ever had a new engine use oil during the break-in period. Is there such a thing anymore? After the change, it was in the hatching on the dipstick, but not at the full mark, so maybe it only used 3/4 of a quart.
Anyway, I asked the Ford service guys where I bought it, and they said that 8.8 quarts is correct. Any thoughts?
Old Jun 26, 2018 | 07:50 PM
msgtord's Avatar
msgtord
Did you wait 15 minutes for the oil to drain down?
Old Jun 26, 2018 | 09:13 PM
smokewagun's Avatar
smokewagun
No. I waited 12 HOURS.
Old Jun 26, 2018 | 09:21 PM
msgtord's Avatar
msgtord
I would think that 12 hours would be plenty of time for the oil to drain into the pan.
I usually check the oil, gaze under the hood and adjust air pressure in the early morning hours. To hot to do it during the day here.
Old Jun 26, 2018 | 10:41 PM
Delta Echo's Avatar
Delta Echo
Mine burned two quarts in the first 2,800 miles. I was not a happy camper, and was almost ready to trade it on another brand (Ford dealer called it "normal"). But then I took a trip through the mountains (working it hard), and that seemed to wear in the rings properly (no more oil burning). Mine was a dealer trade, and had a couple hundred miles on it when I bought it, so I don't know how it was driven for the first few hundred miles. For those who are unfamiliar, babying a new engine is the worst thing you can do for it. It can glaze the cylinders, making it nearly impossible for the rings to seat. It needs some full throttle bursts to get high cylinder pressure and seat those rings.
Do you have the new 5L with plasma coated cylinders, or the sleeved cylinders?
Old Jun 27, 2018 | 01:42 AM
JKBrad's Avatar
JKBrad
Plasma coated. They need to be driven relatively hard to seat the rings. This is not new tech, but new for Ford. It wouldn’t surprise me if this is just a characteristic of the new 5.0.
Old Jun 27, 2018 | 05:35 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I actually has a new short block put into my old '88 f-150. When I got the truck back, the tech told me to break it in like I intend to drive it. So, I wholloped the hell out of it and had no issues for the 125K that I put on it before finally selling it.
Old Jun 27, 2018 | 07:29 AM
JKBrad's Avatar
JKBrad
Tech told me the same about a new Yamaha 250 4 stroke outboard I bought 9 years ago. That block has a similar or same plasma coating process as the new 5.0. Anyway, he told me to run the hell out of it for the first 10 hours, change the oil then use as normal. He explained that the rings had to be set right away or it would use oil for quite some time. I never had any problems with it.
Old Jun 27, 2018 | 08:50 AM
smokewagun's Avatar
smokewagun
Well, I'm over 3,000 miles. Break-in is done. Last 1500 miles were interstate at 72 for hours. If I'm adding a quart every 1500, someone is going to eat this truck, and it won't be me. Especially since the manual says nothing about running the crap out of it to seat rings.
Old Jun 27, 2018 | 08:51 AM
smokewagun's Avatar
smokewagun
Old Jun 27, 2018 | 06:24 PM
Delta Echo's Avatar
Delta Echo
Manuals never say to "run the crap out of it". But I have seen some that said "brief full throttle bursts will contribute to proper break-in".
Seriously, drive it like you stole it for a few hundred miles; you might be surprised at the results. Or hook on a trailer and take it through some steep hills. Cruising at 72 is a very light load on the engine....unless you are doing 72 up a mountain.
Old Jun 27, 2018 | 07:10 PM
GlueGuy's Avatar
GlueGuy
+1. I think the number one thing you can do is to keep the RPM/load changing as much as is practical. If you're droning along at one speed, you may be causing harm. Shift up/down even if you're keeping the same speed.
Old Jun 28, 2018 | 12:41 PM
biz4two's Avatar
biz4two
Arrow
+2. I know we all want good MPG's and all, but while driving along at 72, lockout 10th gear, then 9th gear, then 8th gear for a few miles. Let those RPM's rise...and let some heat build. While in town, put it in SPORT mode. Have a few rabbit launches at red lights.
Good luck with it!!
biz
Old Jun 28, 2018 | 12:43 PM
biz4two's Avatar
biz4two
Arrow
Oh, 12hrs is way to long to check the oil level. The oil needs to be HOT (as hot oil expands). Just wait a good 10 or 15 minutes after the truck is at normal operating temp. Then, give it a check...
biz
Old Jun 28, 2018 | 12:51 PM
smokewagun's Avatar
smokewagun
Well, I brushed off the dust on the Sport Mode this week. Keeps the rubber fresh on the tires.
Ive never heard checking oil level warm, but I'll be... the manual says that. It also says consumption should stop after 3,000 miles. I'm not gonna worry. If it becomes an issue, I'm sure Ford will do a change, seal the dipstick, and check it themselves to verify use. Thanks everyone for the replies.
