Turbo 67 f100 inline 6 300!!
Old 07-22-2018, 08:11 PM
Dusto1002's Avatar
Dusto1002
Dusto1002 is offline
Started and ran fine. Needs timing pretty bad. But it runs fine. Throttle delay isn't horrible. I had a few boost leaks that caused the fuel not to make it to the intake. All fixed now and it starts good.
  #62
Old 07-23-2018, 03:57 PM
Dusto1002's Avatar
Dusto1002
Having a big problem with the carb either overflowing due to pressure or another problem. It will rev at by ear I'm guessing 2500 or so and won't go down. Not the fast idle. No choke electric or otherwise on the car. So I'm not sure whats happening. If it was leftover raw fuel it would run itself down. But it just stays so it must be a carb issue. I also need to gasket and o ring for the fuel rail in between the metering blocks if anyone knows what that's called or where I can get them it would be much appreciated.
besides that and needing a carbon seal. She runs well. If I can get the carb running right I can start on some of the body.
  #63
Old 07-25-2018, 04:13 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Originally Posted by Dusto1002
Right but which way to rotate dizzy if blowing carb off?
Clockwise to retard and counter clockwise to advance the timing. Note the arrow on the Dizzy in the pic below. That is the direction the dizzy spins. There is a mark on the damper. Slot, divot, something. Find it and paint it white. Easier to see with a timing light.
  #64
Old 07-25-2018, 04:32 PM
Dusto1002's Avatar
Dusto1002
Jeff. Thank you very much. I'll save this. I have passed this point and have run into a new problem. At idle it over revs and cant return to a reasonable idle speed. Or slow down at all
  #65
Old 07-25-2018, 04:46 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Some of that high RPM is prolly the timing too far advanced. The gasket and O-rings you need will come in a carb kit. I think you ought to soak it's parts and rebuild it anyways. The accelerator pump nozzles should squirt two streams.
  #66
Old 07-25-2018, 05:23 PM
Dusto1002's Avatar
Dusto1002
It's more like in stepping on the gas and keeping it above 2k on the tach. Advancement should have that large of an effect. The rebuild kit didn't come with that specific gasket
  #67
Old 07-25-2018, 06:10 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Are you talking about #55 and #85 in the pic ?
  #68
Old 07-25-2018, 06:28 PM
Dusto1002's Avatar
Dusto1002
85 66 and 148
  #69
Old 07-25-2018, 07:13 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
85 should have been in the kit. As long as your kit was for a vacuum secondary model 4160. 66 and 148 only if you have a really old Holley carb. Do you?
  #70
Old 07-25-2018, 07:28 PM
Dusto1002's Avatar
Dusto1002
Yea, bought it second hand. I still have the kit I bought I'll look through for about the 10th time in case I missed some o rings and that white plastic piece.
it's definitely a bit long in the tooth. I wish I'd waited and found a mechanical secondary and gone blow through :/
  #71
Dusto1002's Avatar
Dusto1002
didn't hit reply
  #72
Old 07-25-2018, 07:55 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
didn't hit reply
The upper thinner tube is a bowl vent equalizer tube. No gas through it. So I don't think the O-rings would necessarily have to be meant to seal fuel. But I think some accelerator pump fuel transfer tube O-rings for a later 4160 or 4180 would prolly work. I may have extras at home. You can prolly use the same gasket that seals the choke housing and secondary diaphragm housing (46) to the carb body in place of the 148.
  #73
Old 07-27-2018, 02:35 PM
Dusto1002's Avatar
Dusto1002
the tube is definitely leaking fuel. I'll see if a tiny bit of plumbers tape will fix it
  #74
Old 07-27-2018, 04:32 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
The bigger of the two transfers fuel front to rear bowl. If the thinner of the two is you may have the float height too high.
  #75
Old 07-30-2018, 01:02 PM
Dusto1002's Avatar
Dusto1002
fixed the leak and figured out why it was over revving. I fabbed the baseplate for the carb, and hadn't taken off enough material for the butterfly's, so they were getting stuck open just a tiny bit. I only noticed because I couldnt close the throttle manually by hand. A spacer is on the way and that's it besides a brake master cylinder.
unfortunately though I've found out I'm heading back home to california and I'm driving my jeep. So cant bring both vehicles. If your in the area keep on eye on craigslist, you'll get a clean 68 f100 with a whole running turbo set up in perfect running condition before I sell it lol
bigfootsurfin
07-09-2014 03:00 PM
06powerstroke06
Ford Truck Parts for Sale
03-05-2011 08:30 PM
corblund
15
08-19-2010 06:35 PM
PaysonPSD
32
06-29-2010 10:35 PM
67nukeford
Nebraska Chapter
17
02-24-2009 09:12 AM
Quick Reply: Turbo 67 f100 inline 6 300!!
