Turbo 67 f100 inline 6 300!! - Ford Truck Enthusiasts Forums
Old 06-26-2018, 07:25 PM
Dusto1002
Dusto1002 is offline
Dusto1002 is starting off with a positive reputation.
Been turboing my f100 1967 inline 6 300 everything's custom and has been fabbed by me. It's slow but it's happening. So far it's got a Garrett gt38r turbo set up as draw through with 2.5 piping and a Holley 600cfm vacuum secondary carb. Eventually it'll be bagged but it'll retain a rat rod look.
got the car a few months ago and when I have the time or money I do a little something to it.
any idea on how well this turbo will work with this turd?
Old 06-26-2018, 07:27 PM
Dusto1002
Old 06-26-2018, 07:28 PM
Dusto1002
Old 06-26-2018, 07:30 PM
Dusto1002
Old 06-26-2018, 07:37 PM
Dusto1002
Old 06-26-2018, 07:39 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
I bet a pair of small, compound turbos on these '87-'96 4.9L (fuel injected 300) exhaust manifolds would be a screamer on an inline 300.
300 I built and put in my truck 4 months ago.
Old 06-26-2018, 07:42 PM
Dusto1002
that engine bay is way too clean for me 😂 it looks good though! I have another project i keep clean this one is just my beat around.
jeez even your garage is nice!
Old 06-26-2018, 07:43 PM
Dusto1002
Old 06-26-2018, 08:00 PM
85e150six4mtod
85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Check this out. You are a ways into your project, and this one is quite different being a rear mount. However, you might spot a thing or two that will work for you:
https://www.ford-trucks.com/forums/1...6-sleeper.html
Old 06-26-2018, 08:14 PM
Dusto1002
ah I was wondering if this guy was on here. Seen a lot of his vids before I started. I was close to selling the 300 and getting an LS instead and chose to turbo it because of his vids. Didn't know it was rear mounted though! He's got a really cool truck.
Old 06-26-2018, 08:35 PM
J ballan's Avatar
J ballan
J ballan is offline
J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.
Not being a hater because I respect what your trying to do but I have a couple questions. Why did you choose to weld the turbo inlet pipe right to the cast iron exhaust manifold? Also why did you mount your turbo upright? Not saying itís wrong but I donít think Iíve ever seen a turbo mounted this way. Good luck with your build.
Old 06-26-2018, 08:46 PM
Dusto1002
The cast can penetrate and hold well with a weld if it's preheated a bit. I made it like that for ease the way it is i can access every bolt and take off seperately if i want to and didn't have any adapters and really didn't feel like making any. And the turbo is a flipped intake side up to be a draw through. You can't run a Holley 4 barrel sideways last I checked.
Old 06-26-2018, 08:47 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I figured it out J... he's gonna do a draw through..
actually he says it in his original post. I read it, but didn't put the two together either.
Hopefully you put a big enough drain back so its not an issue with turbo mounted that way. Most turbos are t designed for draw through, but if that's a real 38r, the ball bearings might handle it. It typically doesn't have thrust that direction, so I'm unsure if it has ability or not with the ball bearing.
Old 06-26-2018, 08:51 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
If you had researched draw through turbo setups, I doubt you'd find many, if you could, turbos oriented like that. All the of the kits had a 90* bend under the carb to go into the turbo.
Give it a whirl. I don't really see an issue, other than oil drain. Some turbos are picky.
Old 06-26-2018, 08:52 PM
Dusto1002
oil drain back?... hmm hadn't thought of having an oversized drainback, I was under the impression that they operated mainly off of pressure from the oil. It is larger than input but it wasn't on my issues list. And it's a Garrett gt38r off a 7.3 it's also got a weird integrated wastegate that wasn't included that is inside the turbo housings downpipe. Thought it was really really weird to have the Watergate there. Im going to have to weld it open so it doesn't shut randomly.
Quick Reply: Turbo 67 f100 inline 6 300!!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
