Amp Steps and OBD port
Old Jun 25, 2018 | 11:29 PM
SDTruckMan's Avatar
SDTruckMan
if going with the aftermarket Amp Power steps you must use the trucks OBD port. So if you do this, does this mean if you want to hook up something else to this port down the road then you
will need to unplug and plug in all the time the steps in order to use the port, or does it have a piggy back feature where you just plug in on top of it if you have something else.
Is there a way around using the OBD port for the steps?
Old Jun 26, 2018 | 12:11 AM
ACK3000's Avatar
ACK3000
You can find a fairly inexpensive OBD splitter on Amazon. I’m currently using one for Amps and EZ Lynk.
Old Jun 26, 2018 | 10:09 AM
GABAR's Avatar
GABAR
I`m not sure if AMP has gone to one version now but they used to have another version, which was a little cheaper, and it had to be hard wired into the truck therefore leaving the OBD port open. There are OBD splitters so either way, you should be fine.
Old Jun 26, 2018 | 09:33 PM
dkllw1's Avatar
dkllw1
i purchased the splitters from amp OBD is open to use it was worth the $80
Old Jun 26, 2018 | 11:03 PM
SDTruckMan's Avatar
SDTruckMan
links please.
Old Jun 27, 2018 | 01:06 AM
OneCylinder's Avatar
OneCylinder
https://www.realtruck.com/amp-resear...SABEgLWmvD_BwE
Old Jun 27, 2018 | 01:18 AM
jakematic's Avatar
jakematic
Don't pay $80 for that AMP splitter please. I do NOT see the value in it.
I have a decent quality one on my OBD with the steps to use with FORScan etc
Old Jun 27, 2018 | 01:09 PM
fleming23's Avatar
fleming23
Do use caution when buying cheap splitters on Amazon. I tried the one linked below and it did not work with my AMP steps and CTS scanner.
I then spent the money and purchased the splitter from AMP directly and it did work. Not sure of the difference, or maybe the one I purchased was just junk, but the steps did not operate when used.
Amazon Amazon
Old Jun 29, 2018 | 01:20 AM
05yuk's Avatar
05yuk
I have not tried but should be somewhere to tap in to get the door signals.
ohiooutlaw69
Apr 15, 2008 11:42 PM
kodeman05
Jul 6, 2004 03:48 PM
RaiderRay
May 23, 2004 02:51 AM
jayhawk137
Oct 10, 2003 01:27 AM
