trucks!
Old Sep 21, 2003 | 12:35 PM
trojanman25's Avatar
trojanman25
trucks!
im watching trucks and it looks as if they are using propane similarly as someone would use nitrous... does this only work for diesels?
Old Sep 21, 2003 | 12:40 PM
mantta's Avatar
mantta
trucks!
Propane is a conversion for gasoline engines. I have seen industrial diesels running on propane also. The gas pipeline uses natural gas to run their diesels.
Old Sep 21, 2003 | 12:42 PM
trojanman25
trucks!
i think i get it, its a way of adding more fuel, didnt even think... so hes doing propane and nitrous, more fuel, more air
Old Sep 21, 2003 | 12:51 PM
jskufan's Avatar
jskufan
trucks!
Are you saying a diesel engine will run on propane? What modifications have to be done to do this?
Old Sep 21, 2003 | 01:01 PM
mantta's Avatar
mantta
trucks!
When I went to the factory school at Fairbanks Morse in Beloit, WI, they had some Fairbanks Morse natural gas engines that they were re-building. They were identical to the diesels with a few modifications like spark ignition and probably many other things.
Old Sep 21, 2003 | 02:28 PM
AegisSailor's Avatar
AegisSailor
trucks!
I don't even like COOKING with propane, I definately wouldn't want to be exploding it on purpose in the cylinders of my engine!
Old Sep 21, 2003 | 02:55 PM
theologian's Avatar
theologian
trucks!
Diesel engines burn fuel more efficiently when a small spray of propane is injected - similar to nitro, but cheaper. A number of the PSD guys on this site have propane....
Theo
Old Sep 21, 2003 | 04:50 PM
Texan1983's Avatar
Texan1983
trucks!
propane helps run efficently, and cools exhusts gas temps. acualy can be go for it is used right.
Old Sep 21, 2003 | 07:13 PM
DainBramage's Avatar
DainBramage
trucks!
Are you asking about propane injection on a diesel?
No, you can't quite do that in a gasser.
The two have different effects. In a gasser, you can convert it over, and run it as a primary fuel.
In a diesel, it thins the feul, making it burn hotter, faster, ect, therefore providing more HP, but, much like applying nitrous, you have to do so sparingly, and in the right conditions, or boom.
Or at least that's the way it's been explained to me, I've never run it in a diesel (well, other than in the winter, shhhh), but know people that have setup their gassers to run propane.
Old Sep 21, 2003 | 07:17 PM
mantta's Avatar
mantta
trucks!
On the Navy base here in Norfolk, VA about 1/3 of the government vehicles run on propane. They say (and I concur) that it is cleaner burning and that results in longer engine life. You get less acids and condensation in the crankcase from combustion.
Old Sep 21, 2003 | 07:21 PM
Andysutt's Avatar
Andysutt
trucks!
My buddy has propane injection on his PSD..
Runs better, and better gas mileage and burns cleaner
Old Sep 22, 2003 | 10:42 AM
chuck641's Avatar
chuck641
trucks!
the propane injection on diesels is propane gas, not liquid, it is run through a valve thing that makes all the liquid propane from the tank turn to a gas, and it is sprayed into the air intake. its a lot like a dry nitrous system. its also all run through a computer so the mixture is correct
tewferford
Feb 2, 2008 06:14 PM
t_dickie
Sep 3, 2006 02:21 AM
fordtrucklover94
Apr 3, 2005 12:07 PM
