Engine swap
Old Jun 25, 2018 | 12:46 PM
Secallaw5's Avatar
Secallaw5
Engine swap
Hey guys, how hard is it to swap my 170 for a 289 or 302? Would like to do a 289 or 302 and a C4 transmission. Is there a lot of work to do with the steering column to switch to an automatic? Speedway or Summit for a kit or Motor mounts?
Old Jun 26, 2018 | 05:27 PM
85e150's Avatar
85e150
This was a popular swap.
Rather than post a bunch of links, may I suggest you google "early econoline v8 swap". Be sure you have a couple of months to go through all the hits you will find.
Since you have a 170, you probably have a 7 or 7 1/4" differential, so plan on an upgrade there too.
Good luck with it!
Old Jun 26, 2018 | 06:31 PM
EmilBarnabas's Avatar
EmilBarnabas
Which year Econoline? It looks like a 1965-1967, which is good. The cross member under the engine can be modified to hold a V8 and the dog house is better for a V8 than the earlier models.
You our might already have a 9" rear axle. You need that. The 7 1/4" rear axle is no good over 100 HP. See here for axle comparisons.
Econoline Axles
Old Jun 26, 2018 | 06:33 PM
EmilBarnabas
Swapping to a newer 200 engine is a lot easier, and a significant increase in power and durability.
ss27gogeta
27
Jul 10, 2017 11:47 PM
live2hunt
1983 - 2012 Ranger & B-Series
Jun 11, 2007 12:46 PM
jacobyc
3.8 & 4.2L V6
Nov 16, 2004 05:47 PM
BroncoRoadKill
Engine Swaps
Oct 22, 2003 02:28 PM
