91 4.9L - Need A/C Wiring Diagram
Old Jun 25, 2018 | 09:44 AM
1991F250OH's Avatar
1991F250OH
I'm trying to troubleshoot a no-power condition at compressor clutch. Have a low/high pressure circuit continuity (w/LP switch bypassed) but not sure what else may be there (WOT relay?). Just replaced PCM so I don't think that's an issue but if someone also has a PCM pin diagram it would also be appreciated. Thanks.
Old Jun 25, 2018 | 12:27 PM
subford's Avatar
subford
Here is one for a 1990 and a 1991 should be the same or close to it.
Again 1990 and a 1991 should be the same or close to it.
Old Jul 5, 2018 | 07:54 AM
1991F250OH's Avatar
1991F250OH
Problem SOLVED - Appear that previous owner replaced the '91 A/C compressor and hoses with a later model (92-95) which included a HPCO switch. I suppose it would have worked except the LP/HP switches were never connected to the compressor circuit because the harness the guy used had the wrong male end C104 connector. Quick trip to local pick-n-pull and a splice job of the correct connector got the clutch working again, however, it looks like the compressor is probably bad as it began smoking as soon as I got the clutch to engage.
Netroamer
Oct 16, 2021 12:26 PM
wdglide
Sep 17, 2018 10:26 AM
kynnhoj
Jun 2, 2015 08:16 AM
RussB
26
May 22, 2009 02:11 PM
bandit1trucking
Apr 20, 2008 09:31 PM
