351w gear drive
Old Sep 21, 2003 | 09:52 AM
Chris_ce's Avatar
Chris_ce
351w gear drive
I have a 84 351w ho. Will I have to do anything to the block to run a gear drive?
Old Sep 21, 2003 | 02:36 PM
DW2455's Avatar
DW2455
351w gear drive
you shouldn't have to do anything other than install it, but i'd check the various manufactures specifications, I like the belt drives better but there very expensive. DW
Old Sep 22, 2003 | 12:35 PM
stroker393's Avatar
stroker393
351w gear drive
You want have to do any block work but you may have to remove some material from the idler shafts to acheive the correct clearance between the block and timing cover. Your gear drive kit should explain this; most manufacturers do.
