Quad beam upgrade
Old Jun 23, 2018 | 08:20 AM
muecker's Avatar
muecker
Quad beam upgrade
I'm looking at a 2018 lariat. It does not have quad beam headlights. Is this an easy plug and play upgrade or do they require a special harness, ballast, etc? Thanks in advance.
Old Jun 23, 2018 | 08:31 AM
Robb81's Avatar
Robb81
It's not plug n play but it's not that difficult.
It's just expensive to get the factory LED headlights.
https://www.ford-trucks.com/articles...ts-2017-f-250/
Old Jun 23, 2018 | 08:32 AM
muecker's Avatar
muecker
thank you!
Old Jun 23, 2018 | 09:17 AM
ymsmiley's Avatar
ymsmiley
You can run LED replacement bulbs too
Old Jun 23, 2018 | 10:39 AM
Truckie256's Avatar
Truckie256
Like these.... Beamtech. Like $50....
Before
After
Old Jun 24, 2018 | 07:20 AM
GABAR's Avatar
GABAR
I know it`s a pricey option but if you decide to purchase a new truck, spend the extra money getting the factory Quad Beam LED headlights. If you don`t want to go that route, go on a website called "The Retrofit Source" and take a look at the OEM LED headlight kit or the new Morimoto kit that`s coming out soon.
Factory "halogen housings" are not made or designed for LED bulb swaps/replacements.
Old Jun 24, 2018 | 09:53 AM
Poncho450's Avatar
Poncho450
Say what you will, but many here have made that swap and are completely happy with it.
Old Jun 24, 2018 | 11:49 AM
Robb81's Avatar
Robb81
That is true. It's the oncoming traffic that is typically displeased with the aftermarket flood lights.
Old Jun 24, 2018 | 12:12 PM
Truckie256's Avatar
Truckie256
I disagree.... I have Beamtech...and just did 3.5" level lift ...and adjusted headlights down... Still have not been flashed from on coming traffic ...pre lift or post lift.
Waaaaaaay cheaper than factory LED or the replacement LED headlights assy.
Old Jun 24, 2018 | 12:17 PM
cficare's Avatar
cficare
Yeah, folks claim improvements when switching to LED bulbs. I know I did when I installed LED bulbs in my motorcycle 2-1/2 years ago. But I also had to pay attention to how far the bulb protruded into the housing, and rotated the bulb 11° further than the bulb's design allowed to align better with the reflectors. I still like the improved lighting on my bike, but it pales in comparison to the factory LEDs on my KR. LED bulbs emit light much differently than the varieties of glass enclosed bulbs. However, the biggest difference between OEM and aftermarket LED lighting is not due to the bulbs, it's the reflectors. The factory headlight reflectors were designed for LED bulbs where that is not true when one swaps out halogen bulbs for LED.
Old Jun 24, 2018 | 12:32 PM
MDK123's Avatar
MDK123
+1 for beamtechs. Awesome LEDs, crystal clear, good coverage, adjusted perfectly with 4” lift. Factory LEDs are cool too if you’re going for the look of the DRLs and want to stay OEM. For me, I’d rather use that couple thousand to buy other toys. 🤙
Old Jun 24, 2018 | 01:28 PM
1olddogtwo's Avatar
1olddogtwo
The only thing I miss are the factory LED lights in my Platinum. My current trucks have LED lightbulbs, good but not the same.
Neither one of them have High beam's either it seems. Not much different between low and high.
Old Jun 24, 2018 | 01:46 PM
k7lvo's Avatar
k7lvo
Then you’re not running Beamtechs...
Old Jun 24, 2018 | 02:18 PM
1olddogtwo's Avatar
1olddogtwo
550 just in headlights
350 in headlights and fogs
Both are beamtech's, I like them, don't get me wrong. Factory is just better.
Old Jun 24, 2018 | 03:01 PM
PentaPop's Avatar
PentaPop
I’ve always been an XLT guy and been happy with that trim level but I have to say the headlights on my 18 are much worse than the previous XLT I had. They don’t light the ditches like previous trucks did and they don’t cast light as far down the highway. At this point I’ve decided it’s Ford’s way of steering buyers into higher trim levels/expensive headlight packages!
