Pulled the doghouse, found this? And other MISC wires.
#31
#32
Well, i just got a call from the automotive shop doing the work on the Van. They said that they had 2 problems. They managed to get the correct resistor to get the blower motor working but they've also got to replace something called the Multi-Function Relay which is behind the dash.
For the second problem, they were looking at getting the air conditioning system working. Well, it appears that someone has completely cut out the A/C condenser and the cuts looked pretty old and if he was going to guess, he would guess that the A/C compressor was shot and I'd be looking at around $1100-$1400 to have the system replaced. Is it a feasible idea that I could replace the components myself, then have the system filled myself?
#33
I would have expected it to be even more then that. The parts for the front system are readily available. You can also get the rear evaporator but the hoses for the rear system may need to be custom made by a shop that can make them. If you can handle doing the mechanical work yourself then that would save quite a bit on the labor side. But you are still looking at around $500-$800 in parts. Then you'd still need to take it to a shop. Have a vacuum pump hooked up to the system and then have it charged. It's plenty of work but it is doable with some patience.
#34
#35
Don't buy anything right yet... I will be back later today when I have more time to post... BUT I replaced the complete system on my 88 E150 conversion van.. There are several things to look at before ordering parts... Was the original system dealer installed or factory installed? Which compressor did they use? What line fittings are left to make new lines from? I would probably start by searching tor replacement lines and seeing what is available. Some will be very hard to find in mot almost impossible. certain lines match up with certain compressors.. So before you buy anything, make sure you can get everything together for your particular set up..
#36
#37
Pretty much what @annaleigh said. First thing first you need to know if yours is factory A/C or dealer installed. If it's a factory system your compressor kit says it's for a dealer installed. If it's correct for your van I'd prefer the GPD 9731850 compressor kit because it also includes the O-ring set for the whole system.
Then your list didn't have a condenser on it. Rockauto has two choices listed: OSC 4156 or APDI/PRO 7014156.
Then there are the front hoses: FOUR SEASONS 55745 & FOUR SEASONS 56680. Like I said before, the rear A/C hoses might be a custom made only deal. You'll have to look and see what's left on your van. Then do some searching to see if any of it is still available to buy anywhere. Maybe Numberdummy could give you some Ford part #'s for the rear lines to check if they are available anywhere.
Don't rush into it and buy the wrong parts. Take your time, do the research, double check everything and get what you need.
The worse part of replacing these parts is probably going to be the evaporators. Because to replace these you have to tear into the HVAC assemblies. And due to your van's age and the system being open for a while it's best to replace the evaporators too..
I'm still trying to decide if I want to fix the A/C system on my 89 E350 Club Wagon with front & rear A/C. Or I just may remove the whole system all together. Working A/C is real nice, but I work my vans hard and am trying to do everything I can to get them to run cooler. So I may sacrifice the A/C on mine.
#38
He'd have to replace everything today. The old system was for R12, nothing you'll find today for that stuff. Different everything including the lines (seals) And I doubt he'd have a dealer installed system that late a date. Might be simpler to install a 110V window unit in the rear and an inverter to run it. Be a whole lot cheaper. Might not look that great, but his van's no beauty queen anyway. Total cost would be less than $400 for the unit and inverter.
#39
#40
Yea your right, why fix it right when you can cobble and rig something together. Just yank a window out grab some plywood and duct tape and you are all set. And who needs to control the A/C from the drivers seat when you can just ask a passenger to adjust the unit for you. If going non factory unit, a roof mount RV unit would look a whole lot better. But I would fix the factory system.
And that's kind of disrespectful. I think that van looks damn good. Hell, my 89 looks a whole lot worse.
#41
Something else to think, about..
What do you plan on using the van for?
Do you need the rear ac?
Here is my set up for the lines with just front ac.
This is the front ac only and only requires 3 lines.
line 1 which is dependent on which compressor you use.
Line 2
Line 3
Then all is left is the condenser, evaporator, dryer, orifice tube, oil, R134, and compressor...
Line 2
Line 3
#42
Line 2
Line 3
Line 2
Line 3
#43
Thanks for this! One trip I want to take the van on is from Indiana to the Grand Canyon as my mother wants to see it. There will only be 4 of us in the van, so I'm not sure how reasonable rear a/c is or how the front a/c alone will work to cool down the entire interior. Is rear a/c even necessary?
#44
The R12 to R134A conversion is not that complicated.
#45
